spray clear over bare metal for primer ?
beaulieu
We really need a general restoration section,,,,,
I stripped most of the bondo off the front of the car ,
its worse than I thought , so its not going to get done in a week or 2.
So I need to protect the bare metal from rust ,
its going to be from a spray can as thats all I have right now,
I would like to just spray it with clear , so I can see what I need to do later , any reason why not ?
I could spray it with primer in a can (yeah probably better) , but then I cannot see here the braze (yuck) and bad welds are that I will need to cut out later.....
so will clear hurt anything later ?
Beaulieu
martx-5
What I've used in situations such as this, is a sanding primer. It's made to fill in small scratches and be sanded down. This sandability makes it very easy to sand off when you want to get back down to the bare metal.
As far as the bad sections go, why even protect them if you're going to cut them out?? Just primer the good sections, then you'll see at a glance what work needs to be done.
And your right, a general restoration technique section would be nice. Most restoration processes apply to all model cars.
Dave Russell
Yoda - R.I.P
Clear might work to seal out moisture.
As far as primers go, in general there are two types.
Primer/sealer surfacing primer is low porosity & will effectively block moisture.
Sanding primer is porous & will let moisture through to cause rust underneath if exposed to damp conditions for a length of time.
If you are in a damp climate, the clear might actually do a better job of sealing out moisture.
Yep, sanding primer will allow rust to form within a week if the car is out in the elements (or even in a medium to high humidity area). I have an Eagle Talon that has a horribly rusty roof now, because I figgered that primer would hold off the weathering until I could paint the roof.
piman
Hello Beaulieu,
I'm interested to know what is wrong with 'braze', it is a sound metal joining technique used correctly, or appropriately. (As any welding, riveting or even adhesive process should be)
Alec
beaulieu
beaulieu
If done properly I guess there is nothing wrong with brazing ,
problem is getting all the flux off it (same as welding aluminum with flux)
the flux reacts to the paint and the paint lifts,
on this car its not the brazing its the bad work and then the brazing ,
Beaulieu
G
While I was working on mine I spot sprayed the bare spots with the clear finish paint I was going to use on the top coat. It worked great and none of the spots rusted. Then wet sanded it off when I was ready to start painting. I have used primer in the past and if it was a long time on there brfore painting the spots would rust under the primer. I used the spray can variety and don't know why it rusted but it did.
Bob
Platinum
Primers generally are porous so they give the topcoat something to bond to. Epoxy primer is a whole different animal, tho. That seems to seal everything out.
jlaird
Epoxy primer is not porous, it is hard and seals, I mean it is tough. This is the first coat after a blast job. It keeps everything stable. Sanding primer is very porous as said above. Regular paint is a bit porous and should be waxed to fill the porus. Clear coat does the same job as waz by filling the poures and keeping everything tight. Clear coat also makes the finish very smooth to reflect the light and even look wet.
TR6oldtimer
If the car is not exposed to weather or excess dampness, there is a product called Picklex20 that treats the metal and provides a protective coating that will stop rust for several weeks. The metal remains looking like metal. When the time comes to apply filler, epoxy seal, or paint, scuff the Picklexed area, wipe and tack cloth, then paint (FYI areas treated with Picklex should CANNOT be coated with self etching primer)
The stuff is a bit expensive, but like those of you who are part restorers like me and need more time from prep to paint. This stuff works for me.
Simon TR4a Clear spray-on stoneguard? Restoration & Tools 2
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S TR2/3/3A over spray Triumph 18
PeterK General TR Spray bomb Triumph 8
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
D General Tech Spray can shaking Triumph 4
dcoplan Custom color in a spray can? Spridgets 6
S TR2/3/3A spray the paint Triumph 13
Gerard Spray on Chrome Spridgets 33
angelfj1 3Mâ„¢ Paint Defender Spray Film Restoration & Tools 2
S Cold galvanizing zinc spray Restoration & Tools 5
bighealeysource Anyone use the HF HVLP spray gun # 66222 -$35.00 Restoration & Tools 2
D "Freezing Spray" Penetrants Restoration & Tools 9
wangdango Skuffin exising paint/for re spray? Austin Healey 5
B Spray paint tip Restoration & Tools 2
pjsmetana POR-15 & brush marks? Spray Version? Triumph 26
B Anyone have a favorite Paint spray gun ? Restoration & Tools 7
TonyPanchot Black spray from exhaust Triumph 9
tweety Dipstick oil spray/leak/ooze/whatever Spridgets 5
R Samba link paint removal spray MG 62
TR6oldtimer TR6 Spray painting a TR6 engine compartment comments Triumph 26
N Metal spray fender repair Triumph 16
Morris Copper spray and head gasket instructions??? Spridgets 5
Bruce_B Two-Part Catalyzed Primer in a Spray Can? Spridgets 1
MadRiver Cleaning up 3M adhesive spray? Triumph 18
M over spray removal Jaguar 6
T Anyone every spray paint/primer with one of these? Triumph 34
R Source for spray cans of touch-up paint? Triumph 12
T Spray booth rental in SoCal Triumph 0
C Signa Red in Spray Can??? Triumph 8
S TR2/3/3A $10 in spray paint vs. TR3's engine bay Triumph 10
S Spray-can engine bay painting effort Triumph 10
Z Copper spray and coated head gaskets? Triumph 0
G Spray Painting Restoration & Tools 10
P Gray spray paint Jaguar 1
A Orange spray detailing stuff Restoration & Tools 0
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
AH67AH Clear Lenses Austin Healey 8
aero3113 3000 with clear hard top?? Austin Healey 11
M For Sale Clear Hooters Horns Other British Classifieds 0
KVH General Tech Clear Coat Application Triumph 6
princetn1 MGB Clear or tinted, that is the question. MG 11
O TR2/3/3A clear coat Triumph 2
drooartz Single stage vs base/clear Spridgets 29
J Protecting new wiring harness under car section-Use clear shrink tubing? Austin Healey 4
H clear coat question on scuttle Austin Healey 7
NutmegCT clear coat rub down Restoration & Tools 7
D Aluminum protectant/clear coat Spridgets 6
D How do I clear up a plastic rear hard top window? Restoration & Tools 3
T TR2/3/3A Is stock TR3A windshield tinted or clear? Triumph 9
