I have the compressor, spray gun & paint.
Ok, I understand on some level that preperation is a big thing. Assuming the car is prepped well enough and I'm ready to start spraying. What do I need to know. Things I don't comprehend to well .. are reducer what is it how much do I need, same with hardener and same with clear coat.
How much pressure do I need at the gun and what technique should I be using to get a decent spray job. I sprayed my car with spray cans last time around and felt I got a good finish when I saw the paint getting wet. Too much tho and I was getting runs, too little and I was getting a dry dull coating. Is it best with a few thin coats or a couple of wet coats. How long do I need to leave between coats. I am using acrylic paint.
Any good web sites on how to do your own spray job ?
-Gary
-Gary
