Dipstick oil spray/leak/ooze/whatever
tweety
I think oil is spraying, leaking, oozing or something..... Out of the dipstick neck.
I've heard it's a problem with a 1500 midget '79.
Any suggestions?
Jim_Gruber
Vacumn needed to create negative pressuse in the crankcase?
jvandyke
I'd make sure you have the crankcase vent set up right like Jim said. It did wonders for me, then if you still have issues go after them, otherwise you're chasing symptoms.
Midget78
Yep, just had this problem when the Weber conversion went on. The crankcase not properly being pressurized will cause this. Follow the link Ed has attached above or if you have further trouble let me know and I can help you through how I resolved it.
P No Oil on Dipstick Other Cars 1
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
J TR6 Oil Dipstick Tube Triumph 8
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
pjsmetana My Oil Dipstick has 3 lines Triumph 11
C Oil coming out the dipstick Triumph 7
johnrip Wedge tr7 spurting oil from dipstick Triumph 6
O Leaking Oil around dipstick British Motor Corp 5
R Healey 100 Dipstick Stuck Austin Healey 12
D Gearbox Dipstick (BT7) Austin Healey 3
F BJ8 Dipstick Broke Austin Healey 14
W Bugeye dipstick...... Spridgets 13
Csarneson Early bn4 dipstick tube removal Austin Healey 7
Rut MGB Dipstick info needed MG 2
DanLewis Wrong dipstick? Spridgets 37
T Bj8 dipstick Austin Healey 2
CanberraBJ8 BJ8 dipstick Austin Healey 13
pipercollins 1500 Drain Plug with Remote Dipstick Triumph 7
T TR2/3/3A TR3 tranny, dipstick and fill Triumph 3
Westfield_XI A leaky dipstick Spridgets 5
memphis Gearbox Dipstick - Above High Mark? Austin Healey 3
rlich8 Dipstick Leaking Triumph 4
B 86 xjs trans dipstick Jaguar 0
I Gearbox dipstick Austin Healey 5
memphis Access Panel to Gearbox Dipstick Austin Healey 3
G Quick fix for leaking dipstick Spridgets 0
johnrip Wedge TR7 with K&N Air filters. Where to mount dipstick? Triumph 2
pjsmetana DGV adjusts and 3 line dipstick - Latest Triumph 7
jvandyke Correct dipstick set up Spridgets 6
J Can I drive with dipstick pipe in sump? Spridgets 6
F 67 BJ8 with wrong dipstick Austin Healey 3
B Dipstick location on 1500 engine?? Spridgets 11
A Dipstick tube not made anymore? MG 2
BritCarFan Engine RPM slows down after removing dipstick British Motor Corp 2
aeronca65t Measurement of 1500 Dipstick? Spridgets 3
aeronca65t Measurement of 1500 Dipstick? Triumph 5
White79MGB TR2/3/3A Access to TR3 tranny dipstick? Triumph 3
H 3 ltr engine BN4 to early BJ8 - dipstick markings Austin Healey 8
C Dipstick Austin Healey 3
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
