Samba link paint removal spray
aeronca65t
Not bad.
It seems to depend on the quality of paint you're removing, but it looks like a great way to deal with a previous, cheap re-spray.
Thanks.
hottvr
Wonder what you use to treat the fender with after it has been stripped and will primer still stick to the fender after it's been used.
Rick
Platinum
Good thinkin' Rick.
I'd use it on file cabinets, tho. :wink:
R
racetearoffs
Rick
I am going to wrap the car with 3m material printed after i get all the paint off . I am going to make sure i get the rust off and a simple primer will be used .<<< I hope i can find something to stick !!!! I can wrap the car and not have to worry about the expense of paint and body time and labor . Wrap print is about $250 gonna use for promotion of business . I can worry about paint restore in a couple of years if ever . The wrap will save the body as is until then .
I am waiting for a case to get to the local Ace hardware then i will get some pics after its down to the metal . I am thinking of Brit rock star type deal the who /stones ect ? Not gonna do the Austin powers deal .
ronzet
racetearoffs,
The video looks impressive.... although with my paint job the pressure washer might be enough... :smirk:
I think I am going to give this a try... Just to make sure.. It is Dawn Power Desolver?!?!? and where can you buy it???
ronzet
Racetearoffs,
I am stripping my engine compartment and will give this a try on the weekend... I'll let you know how it faires...
beaulieu
its pretty hard to find ,
I got mine at an Ace hardware too,
but never found it at Walmart or a grocery store,,,,,
GTsRFine
Found it at Wal-Mart here in Augusta. I put it on one half of an old greasy, dirty MGB timing cover and put a plastic baggy around it. That was about 4 hours ago. I think I'll go out and see how it is cooking. If it is worthwhile, I'll post the results.
GTsRFine
OK - I'm impressed.
Took the timing cover out of the bag, wiped off the dissolved grease with a paper towel. Gave it test portion a quick hit with the scraper, then rinsed it off with a garden hose. Here's the results in the attached photo:
A longer cook-out period would have given better results I think. Also something stronger than a garden hose would have been better also. Despite these quibbles, this stuff will save a lot of labor and wear/tear on the air compressor/bead blaster when you are refreshing your engine.
Bruce74B
My wife found some at the local grcery store and I used it to degrease the master cylinder bracket when I R&Red the MC this weekend...sprayed it down, let it soak for about 20 minutes and 34 years of crud rinsed right off. A little Metal Prep and POR15 will make it like new...great stuff!
Bruce
ronzet
I am thinking that this might work well in my engine compartment... (for pictures - refer to the Progress Report that I have posted today).
Although it may melt anything that I haven't removed!! :smirk:
Ya' know, if this works as well as it seems, it is a boon as a labor saving device for we car nuts!!
mgb4tim
I have an old pair of fiberglass fenders that have cracking paint on them. I wonder how it treats gel coat.
I'll test a piece of fiberglass scrap after heading to Ace tomorrow for a bottle.
My mom swears by the stuff. She had an old skillet with burnt on crud - sprayed it, let it sit 5-10 minutes, washed it off in the sink, and it came clean.
Heck, let me ask the wife if we have any in the kitchen-wouldn't that be a treat!
!Edit!!
My sweet, sweet wife had a bottle under the sink. I sprayed a piece of fiberglass, both sides, that has a few aluminum riv-nuts and a couple black-oxide coated stainless screws in them, 1/4"-20 x 3/4", if you are wondering.
Soaked it all down in a zip lock, and will see what prevails in the AM.
Platinum
I was wondering about this, Tim. Suspect it'll eat into th' gel AND the resin tho.
mgb4tim
The results are in after a 12-hour test.
The zip-loc bag suffered the most "damage". I set the bag in the sink over night, which I am glad I did. The outside was all slimy, as if the Power Dissolver had permeated through.
I washed the piece off with cool water in a utility tub, and the gel coat was fine, the resin was fine, and the aluminum riv-nuts were fine. The black oxide coating on the SS screw was transparent.
So. the next test will be a small portion of the fiberglass fender I have, to see if the paint comes off. I bet covering it with clear plastic and setting in the sun would kill it. I think black trash bag in the shade would allow it to stay wet longer and penetrate better. Thoughts?
Platinum
Yup. No direct sunlight. And I'd expect it to eat biodegradable plastics... I'm still concerned about what it'll do to 'glas resin, tho.
dklawson
Fascinating. I'm stripping the Spitfire floors to apply POR and just bought a gallon of Bix stripper. I'll postpone that a couple of days while I look for the Dawn product. It sounds too good not to try.
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
D MGB Rear Suspension Damper Link Arm MG 2
banjojambo Triumph tr3 vertical link wobble Triumph 2
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
V TR2/3/3A Vertical link check Triumph 2
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
S TR2/3/3A Vertical link Triumph 3
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
N Watts Link??? Spridgets 2
H broken sway bar link - again Austin Healey 8
T TR2/3/3A tr3a verticle link removel question Triumph 11
G BJ-7 Rear Shock Link Austin Healey 2
B Support bracket for the rear suspension damper link Austin Healey 5
D TR4/4A stubborn lever shock link Triumph 2
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
N Top link offset bushings?? Spridgets 6
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
T TR5/TR250 250 Sway Bar Link Triumph 0
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
DornTRoriginal TR2/3/3A Horizontal Link Assembly Install Question Triumph 1
J TR2/3/3A Need a TR3 vertical link Triumph 1
D TR2/3/3A Vent lid link length Triumph 8
J TR4/4A 67 IRS Damper arm/link removal help Triumph 10
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
S TR4/4A Reversing upper fulcrum link Triumph 3
B Parts for sale on Panjo link Austin Healey 0
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
K Jaguar 140 Restoration Link? Jaguar 2
Morris OOS Upper Link Spridgets 6
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
K TR2/3/3A Silent bloc bushings in the drag link. Triumph 2
BobbyD Off Topic HiJacked Forum Link? Triumph 4
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
aeronca65t MGB Excellent MGB info-link MG 0
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
drambuie Check out this Healey 100 with a Jag V12 convertion [click on the british v8 link] Austin Healey 5
H broken sway bar link Austin Healey 13
TimK How do you post a link to an older post/thread? Austin Healey 4
T TR2/3/3A TR3B vertical link Triumph 13
K Link to pic of 4 inner sill install without floor? Triumph 0
T Help on ball joint - vertical link fit Triumph 20
W Link to my intro Austin Healey 0
Willie_P TR4/4A Custom Shock Link: idea [Tr4] Triumph 1
