broken sway bar link
Hoghead
My BJ8 sway bar end links were bent at the threaded ends so I fitted new ones with urethane bushings from Moss along with urethane centre bushings.
Now the R link has broken on the bottom end at the thread where the bushing is located
Difficult to see how I could be installing it incorectly but it would not be the first time.
Am I doing something wrong, or is it the urethane bushings
AH100M
If I recall correctly, the anti-roll bar links should be tightened up with the car on the ground and the front suspension in its normal laden position. Also, snug up each nut on the links just so the bushings start to compress. That said, I've only used standard rubber bushings so I can't say it's NOT the urethane bushings causing the problem.
H
Hoghead
Bill - loaded it as you suggest
My end links are not at right angles to the bar and at a rather acute angle, putting a lot of stress on the end link. It is no wonder the stock one bent and does not look right
H
Hoghead
I was wondering sbout that too, and if there is a way to mount something incorrectly you can bet I tried it first
AH100M
There are good drawings of the front suspension and steering in the factory shop manual. Is the anti-roll bar original? An incorrect part may be to blame as much as incorrect mounting would be. When I first restored my 100 I found that one front spring was 3" longer than the other. I never figured out what car the wrong one came from.
pkmh
I hope my enclosed photo helps and I hope I did mine correctly. Haven't had any problems, thus far.
AH100M
pkmh's picture shows how it should look. If yours doesn't look like it start replacing parts (start with the cheap ones first!) until it does. I don't see how wrong links could be the culprit. Wrong bar?
BigGreen
One picture from the internet;
And one from my own car, with blue polybushes. Note the extra strip to hold the Spax shockabsorbers (behind the original spring)
Hans
PeterC
Hoghead said:
mine is not straight up and down like that, and my ends are splayed outboard
I suspect something is or was wrong up front.
As evidenced by your shocks.
Contact me, please.
Peter
red57
Probably not on backwards. My guess, you've just got them on the wrong side - swap the right to left and left to right and everything will line up.
H broken sway bar link - again Austin Healey 8
D TR2/3/3A repairing broken hardboard seatback Triumph 8
Bayless How to repair broken vent window studs? Spridgets 1
M TR6 1973 TR6 - broken choke cable Triumph 6
P Broken Overdrive Switch in Gear Knob Austin Healey 14
AH67AH Broken Shock Mounts Austin Healey 23
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
K What is this broken part in my transmission/OD? Austin Healey 6
tahoe healey Broken Spokes Austin Healey 8
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
KVH General Tech Clutch Fork and Broken Pin Triumph 8
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
B wire wheels and broken spokes Austin Healey 19
I TR6 Broken front suspension bracket Triumph 3
D TR4/4A broken trans fork pin Triumph 14
mcmillal TR4/4A Broken Vertical Link Triumph 17
D BJ 8 Side window broken - Help !! Austin Healey 9
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
C TR6 Broken Throttle Shaft Triumph 4
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
B TR4/4A TR4A Head off for broken manifold stud - What else to do ? Triumph 13
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
P BJ 8 broken hood frame screw Austin Healey 6
TomChar TR6 '74 Clutch & various broken bits Triumph 20
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J TR2/3/3A Broken pinion gear tooth, I am sad! Triumph 2
A Broken Axle Question? Spridgets 11
Gliderman8 Help with restoring broken aluminum logo badge Restoration & Tools 6
J Need some expertise, broken exhaust maniford Triumph 9
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
K Anyone experience a broken crosshaft pin.... Triumph 6
K TR2/3/3A Crossshaft broken taper pin removal? TR3 Triumph 5
P broken oil cooler fitting MG 1
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
nevets Points failure - broken cam follower Austin Healey 3
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Westfield_XI Three broken spiders later..... Spridgets 54
tahoe healey broken spoke Austin Healey 12
V Help: key broken off in ignition! Triumph 18
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
B High Torque Starter Broken mount Austin Healey 1
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
middie Is this sender wire broken?? Spridgets 2
K BROKEN ROD BOLT has any body had one? Triumph 9
davester Help needed...broken exhaust manifold stud MG 15
jvandyke hood [bonnet] release broken cable Spridgets 34
M Broken Ball Joints Spridgets 14
