Points failure - broken cam follower
nevets
A few weeks back I broke down on the road, resulting in my Healey being hauled home on a flatbed. I finally got around to investigating the problem and discovered that the plastic cam follower on the distributer points broke. I have not encountered this failure mode before. See attached pic.
Keoke
No Nevets that is a strange one on me.Course no if ypu had a pertronics this would not of happened.--Keoke-- :laugh:
TimK
The cam should be lubed which should help prevent this:
I found the following on line:
"Mallory Distributor Lube (Cam Lube Grease), .25oz, 26015 is the PROPER high temp grease to use on the distributor cam lobes, where the rubbing block of the points rubs against. This location is often dry, resulting in "squeaky" points operation.
This high temperature grease won't fly out onto your points like Vaseline, or other greases! STICKY to stay on the distributor shaft and centrifugal advance mechanism. This is also EXCELLENT for the needle bearings for your transmission input shaft, it's usually inside the engine's gland nut.
You should put some of this on the point lobe every 3k miles. This is also GREAT for input shaft and throwout bearings (inside the gland nut or flywheel), since it won't get hot and then fly out onto your clutch! Also used for generator or alternator bearings. This is a must for your garage. "
C TR6 Seatbelt anchor points Triumph 2
L T-Series Back to org. points MG 3
P TR2/3/3A NO spark at points Triumph 36
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
W Seatbelt Anchor Points Austin Healey 2
T TR2/3/3A bad napa points Triumph 9
steveg Points assembly order of washers Austin Healey 13
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
K TR2/3/3A Disributor Points Triumph 3
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
T TR2/3/3A tr3 points& condenser#'s Triumph 6
C MGB Attachment points MG 4
Jim_Stevens TR2/3/3A Sway bar attachment points Triumph 3
JFS TR2/3/3A Engine Removal Attachment Points Triumph 8
K TR4/4A Distributor Points and condensor insulating washers..... Triumph 14
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
R TR2/3/3A Ignition points Triumph 3
R Ignition points Austin Healey 21
doc50 TR2/3/3A Question about points. Triumph 6
C TR4/4A Sudden loss of points gap Triumph 10
B TR2/3/3A Vent cowl lid mounting points Triumph 3
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
S Points versus Pertronix Spridgets 22
Michael Oritt MGB MGB gearbox identification points MG 1
C TR4/4A Burning through points Triumph 4
RedTR3 TR2/3/3A Best Ignition points set? Triumph 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
TomR 1978 MG Midget with Points Distributor Spridgets 4
AUSMHLY Pertronix or points Austin Healey 49
Lukens TR2/3/3A Distributor... going back to points. Triumph 8
HealeyRick BJ7 Door Seal Attachment Points Austin Healey 0
Jeepster BJ8 exhaust mounting points Austin Healey 17
S Original Lucas Points Austin Healey 4
Marvin Gruber New points problem Austin Healey 1
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
tri_carb_healey brake drum work, proper jack points Austin Healey 12
drooartz Pertronix back to points MG 28
lbc_newbie Best anchor points for shipping a Midget Spridgets 8
K Those who switched back to points from petronixx.. Triumph 64
G TR2/3/3A TR3 Grease points Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
Ken40 MGB-GT 67 B/GT unibody datum points MG 0
O TR2/3/3A Best jack points/location stands TR3 Triumph 4
