TR4/4A Burning through points
carpecursusII
I did a quick general tune up the other day, including valve lash, point gap and plug gap. I drove maybe a total of 25 miles and the last few miles the car quickly developed a bad miss. I got home and found the point gap to be very wide .020+. I know that I set it at .014 and the car ran great at that setting, I just reset it to .014 and the car runs great again. What would cause quick wear to the points?
TR3driver
Great Pumpkin - R.I.P
My opinion, there has to be something else going on, like the point plate was tilted or the point set is defective. The contacts can't have worn that much in 25 miles.
I have seen rubbing blocks wear that quickly, but that closes the gap rather than opening it.
Brinkerhoff
More than likely, the set screw wasn't tightened or you didn't set the gap properly . There just isn't enough wear going to happen in 25 miles .
glemon
I was going to say, doesn't the gap close as points wear? The rubbing block that is opened when the cam on the distributor drive hits it wears down and the points gap closes, at least that is how I recall it working both in theory and in practice. As noted I would guess something wasn't tightened down all the way and it moved, or was a little askew and it settled, as Geo noted set, them again, observe how everything goes going, measure twice, tighten once, and hopefully will all be good, and stay good.
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
2 TR2/3/3A Something's burning Triumph 13
HighAltitudeTR3 TR2/3/3A Just started burning some oil... Triumph 8
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Sopwith_Camel General MG Spring and the smell of burning eclectics are in the air MG 4
Keith_M 1275 burning coolant Spridgets 20
J New engines burning oil, Too much fuel? Triumph 14
aeronca65t Midget-flipping and burning in slow-mo Spridgets 11
J Burning Dynamo Austin Healey 2
athenssprite Smoke - oil burning Spridgets 5
athenssprite heavy smoke on start up - burning oil Spridgets 13
D Oil burning at cold start Austin Healey 17
longbridgehealey somethings burning? Spridgets 10
S Got 800K burning a hole in your pocket?? Jaguar 9
P Starting problem .. and a burning problem?? Austin Healey 11
gubba Burning Wires...Yikes...Help Please Triumph 5
2wrench TR6 TR6 Burning/losing oil, what do you think? Triumph 7
D Burning Oil Triumph 7
D New rebuilt engine-burning oil after 700 miles?? Triumph 5
Webb Still Burning Oil? What Type of Oil to Use? Triumph 20
G Burning Fuses & my patience..running out of both Triumph 25
Hegg Elan +2 is burning oil [come on in and laugh!] Lotus 8
Patton Burning up rotors - plus tech tip to get home!!! Austin Healey 16
D MGA Oil Burning MGAs MG 2
5 BJ7 Boot Rust-Through Austin Healey 13
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
AUSMHLY 1967 Mark III, Phase I through III and counting Austin Healey 38
Hamish Racing TR2/3/3A Pictures through a corner. Triumph 7
S TR2/3/3A “burn through primmer” Triumph 8
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
A MGB-GT Video- Three minute run through Smugglers Notch in Vermont. MG 4
A Spitfire Video- Three minute run through Smugglers Notch in Vermont. Triumph 4
D TR2/3/3A Clutch through out fork misaligned Triumph 17
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A busted through to bare metal Triumph 18
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
J Backfire through carbs Austin Healey 3
kennypinkerton Seeing it through... no matter the result. Other Cars 0
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
AN5Sprite How My Sprite Got Me Through A Blizzard... Spridgets 6
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
M Backfiring through carbs still Austin Healey 17
maxwedge5281 braking circuit through the stop light switch Austin Healey 7
Darrell_Walker General TR View through the windscreen Triumph 15
Don_Racine 15% OFF Spridget Parts through Memorial Day Spridgets 1
BlueMax Griffin Comes Through Spridgets 0
T everyone make it through the storm OK? Triumph 18
arizonamike Triumph 6 cylinder engine '67 through '76 Triumph 29
