Backfire through carbs
Jimkayh
Any help is appreciated. After I had the carbs rebuilt I began to have a constant backfire at all speeds. When I disconnect the #1 spark plug wire the backfiring stops. I have replace wires and distributor cap.
Jim 58 BN6
Well, the first thing I would check would be that the plug wires were replaced on the cap in the correct order. From what you are experiencing, I think you might have a couple swapped, especially since it does run, and the backfiring goes away when you remove #1, so probably #1 is swapped with another. GL, Jim
RDKeysor
Bronze
For sure having two spark plugs incorrectly connected--it has to be two--will give you some rip-roaring backfiring. Did that just last week!
dklawson
Once you confirm that the firing order and plugs are correct, turn your attention back to the carbs. Make sure they are working. Check the level in the float bowls and go through another mixture adjustment. Make sure the vacuum pistons are free and not binding in their travel.
If you have not touched the ignition system and start experiencing backfires from the carb it is often a symptom of an extremely lean condition... like running on one carb.
S Backfire through rear carburator Austin Healey 18
K TR2/3/3A Missfire and Backfire Triumph 141
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
K Midget backfire at intake side... Spridgets 7
M TR6 1975 TR6 Backfire from Carbs, running Lean - Help! Triumph 9
tinman58 TR2/3/3A Backfire! Triumph 13
T Spitfire Backfire Triumph 1
D Carburetor Backfire on acceleration at low speed Austin Healey 18
H Backfire on deceleration MG 6
D BT7 Tri carb Backfire Austin Healey 2
Jim_Gruber Sputter, miss, backfire, Yuck!!!! Spridgets 27
roofman Spitfire Spitfire backfire, timing or carb? Triumph 12
JPSmit tonight - backfire Spridgets 10
T What causes an engine to backfire? Triumph 15
G Engine Backfire Austin Healey 13
J MGB 1976 mgb backfire MG 5
D MGA mga start and backfire MG 5
R Backfire during decelleration MG 14
R backfire...ect. Austin Healey 50
SilentUnicorn Backfire question Other Cars 11
jerrybny My clunk is gone too and Backfire question Triumph 10
73MidgetLigon mg backfire dcoe Spridgets 31
A TR4/4A TR4A backfire - help please Triumph 15
B TR4/4A Tr4A carb. backfire Triumph 3
S Wedge Finally! I figured-out the TR7 backfire problem!!! Triumph 3
S Wedge Help in solving TR7 lift-off backfire Triumph 9
M Help with backfire and smoke Triumph 2
5 BJ7 Boot Rust-Through Austin Healey 13
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
AUSMHLY 1967 Mark III, Phase I through III and counting Austin Healey 38
Hamish Racing TR2/3/3A Pictures through a corner. Triumph 7
S TR2/3/3A “burn through primmer” Triumph 8
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
A MGB-GT Video- Three minute run through Smugglers Notch in Vermont. MG 4
A Spitfire Video- Three minute run through Smugglers Notch in Vermont. Triumph 4
D TR2/3/3A Clutch through out fork misaligned Triumph 17
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A busted through to bare metal Triumph 18
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
kennypinkerton Seeing it through... no matter the result. Other Cars 0
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
AN5Sprite How My Sprite Got Me Through A Blizzard... Spridgets 6
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
M Backfiring through carbs still Austin Healey 17
C TR4/4A Burning through points Triumph 4
maxwedge5281 braking circuit through the stop light switch Austin Healey 7
Darrell_Walker General TR View through the windscreen Triumph 15
Don_Racine 15% OFF Spridget Parts through Memorial Day Spridgets 1
