MGB 1976 mgb backfire
jiml
i have done a complete engine rebuild, installed a pertronixs unit,set timing and fiddled with ZS carb. engine ran good for a short time until it developed a slight backfire out the exhaust when the gas pedal is released. any suggestions?
Platinum
If all your emissions equipment is in place, the usual suspects: The "gulp" valve first. It's a can-like lookin' thingie in the air pump plumbing. There's a check valve at the air rail and an EGR valve on the exhaust manifold. Those need testing too.
Nittany Lions!!! WooHoo!!!
J
jiml
thanks i will check the gulp valve and egr valve. this may help fire up the nittany lions this saturday.
Tom_Fisher
Dr. Entropy is right, Jim. I would suspect the gulp valve. From what I've read they are of a very poor design and prone to failure.
Don't know what state you're in and, consequently, have no way of knowing if you can legally remove the emissions stuff. But if you can, do yourself a big favor and do so. I removed my emissions stuff (air pump, injectors, and gulp valve) about 3 years ago and the backfiring I had been experiencing all went completely away.
If you'll look at many MGB engines that show up periodically on these forums, you will note that the emissions stuff on most has been removed. Let's face it - MG only came up with that stuff (emissions control system)
in order to comply with U.S. regulations at the time. I doubt the MG people really put a lot of engineering know-how behind this effort.
twigworker
Gulp valves do indeed go bad but most of the time the "failure" is in the little vacuum sensing line running from the manifold to the side of the valve. One or both of the rubber hose connectors can crack and leak vacuum resulting in no function of the valve. Check that first and at the same time make sure that the metal stub pipe sticking out of the side of the valve is secure in its boss. If it is loose you can either drive it back in with a hammer whack or use something like JB weld to hold it in place. Check all of this stuff before you go buying a new valve.
Usually though a non-functioning gulp valve will result in a BIG backfire in the exhaust. The above is easy to check quickly, but before you buy a new valve go back through your tune and make double sure that all is set correctly.
Jack
J
jiml
after receiving several suggestion about a faulty emissions system (gulp valve, egr valve) causing an engine to backfire,i quickly removed the air pump belt and successfully ran the engine without a backfire.
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
R MGB 1976 MGB restoration question MG 11
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
S MGB 1976 MGB Runs Hot MG 23
Y MGB 1976 MGB for sale MG 0
B MGB replacing 1976 MGB ignition MG 1
G MGB 1976 MGB Sebring Valence Kit MG 9
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B TR6 TR6 1976 Clutch Choice Question Triumph 3
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
K 1976 BMW 530i Other Cars 3
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
D TR6 1976 TR6 Fuel Lines Triumph 7
D TR6 1976 TR6 Rebuild Triumph 11
M TR6 1976 TR6 Ignition problem Triumph 6
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
J TR6 Need front bumper for 1976 TR 6 Triumph 6
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
S TR6 Paint in a 1976 TR6 Triumph 8
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
R Spitfire 1976 spitfire wiring harness Triumph 2
Thor Can the 1976 plus radiator fit 1975 midget & Spridgets 7
