TR6 1976 TR6 Rebuild
Don_Houston
I just purchased a 1976 TR6 with 23k miles, it has been in storage for about 28 years. A friend of mine examined the car, I have not seen it yet. Minimal surface rust on the body and interior in B+ shape. The engine was started up after changing the oil, and putting gas in the carbs (tank is likely gummed-up). I am going to try and do as much work myself as I can, so where to start?
What is the best parts website (there seems to be many) and what are the recommended brands?
How do I prioritize what to do first to get the engine running safely?
I have been advised that I will likely need to clean the fuel tank and filler tube, new fuel lines, pump and rebuild the carbs - sound right?
Anybody in the League City Texas area?
Thanks for your help - I will need it all!
TexasKnucklehead
Don, welcome,
I dropped off my TR3 tub yesterday just up the road in La Marque.
My red '74 TR6 has been in League City more than once, but I live in Spring.
The first thing you should do is join the TTR. You know we're hosting a national VTR meet in Galveston in October?
I'd clean the tank and lines, but doubt the lines will need replaced. All the fluids need replaced. The brakes need to be carefully inspected before you find out the hard way they are not up to snuff. Also find out how old your tires are, and replace them before they blow out on you. What type of 'rebuild' are you looking to do?
'The roadster factory', and 'Moss' are my favorites, but check the advertisements on this forum.
Jer
JodyFKerr
Ditto on what was previously said.
Plan on rebuilding the brake system. Basically anything in there that's rubber will be shot.
Once you can start, drive, and stop then start worrying about the other bits.
TexasKnucklehead
Let me clarify what I said about the gas lines. The hard (steel lines) should just need cleaned. There are a few short sections of rubber used to connect the tank to the line, and the line to the pump and filter, that I would replace while cleaning the lines. They dry rot, crack and eventually will leak.
Enjoy your new toy and post some pictures.
Don_Houston
Thanks for the comments so far. I will try to post a few "before" photo's to have more gratification on the "after" photo's.
Can anyone comment on my question on the quality of parts? I want to buy the best needed, but don't need to go overboard for little value. Are their a few manufactures that you really trust?
Don_Houston
I am ready to start my rebuild and will rebuild the carb first. Moss has a "Master rebuild kit" for $134 and a "rebuild kit" for $80 without any description of whats in the kit. Which one do I need? The engine has 23k miles on it but has not been driven in 20 years.
How do I post photo's?
Mickey Richaud
Don - check here and scroll down through the list of parts. Some will say "Included in Master and Standard Rebuild Kits", and some say "Included in Master Rebuild Kits". Throttle shafts and disks, some hardware, etc.
Check here
:cheers:
Mickey
poolboy
Make sure that whichever kit you buy you also get a Throttle Bypass Valve DIAPHRAM. As yet I have not found a kit that includes it so I buy them separately. Some kits don't even include the o-ring seal for the damper well that goes around the needle adjuster.
Tip: clean again and again and test for reliable function the float chamber needle valve that you will get in the kit. I've had to reject several brand new ones in favor of reinstalling a reliable old one.
I usually buy the Victoria British kits and the other 2 items I mentioned as not included separately
https://www.buckeyetriumphs.org/technical/Carbs/CarbsI/CarbsI.htm
TR3driver
Great Pumpkin - R.I.P
I would say it's mostly a crap shoot. In general, we don't even know who manufactured a part, they generally show up with only the required "country of origin" identification (and sometimes not even that). On the rare occasions where there is a name on the box, they have almost always bought the part from someone else and put it in their box. And unfortunately, by the time that word gets around of poor quality parts, generally new ones aren't made by the same factory any more anyway.
There are a few names left, like Timken & Robbins; but others like Lucas, Girling and TRW have been sold so many times that they are basically meaningless today.
TR3driver
In that case, most likely you will be fine with the lesser kit. The "Master" kit includes things like throttle shafts that don't normally need to be replaced unless the carb has a LOT of miles on it.
Don_Houston
I finally got started! Questions:
1.) I have pulled the gas tank and am getting it cleaned and coated.
2.) I have set up a hose and funnel on the fuel line using "Marine Clean" solvent. I think the fuel line is really gummed up after sitting for 30 years. Is there a stronger solvent I could use?
3.) Or will I have to replace the whole fuel line (I already replaced all of the flexible portions)? If I have to replace the fuel lines, the clamps are riveted to the frame and will likely break anyway, so is there a common solution for this?
4.) I pulled the radiator and will have a shop check that for me. I will be replacing all hoses and thermostat at this time. With the radiator out should I do some kind of extra flush on the engine, and if so how do you do it?
(clutch and brakes are next on the list!)
Many Thanks!
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
B TR6 TR6 1976 Clutch Choice Question Triumph 3
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
D TR6 1976 TR6 Fuel Lines Triumph 7
M TR6 1976 TR6 Ignition problem Triumph 6
S TR6 Paint in a 1976 TR6 Triumph 8
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
T TR6 1976 Triumph TR6 For Sale in Classified Section Triumph 0
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
P TR6 1976 tr6 specs Triumph 3
B TR6 1976 TR6 For Sale Triumph 2
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
K 1976 BMW 530i Other Cars 3
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
R MGB 1976 MGB restoration question MG 11
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
J TR6 Need front bumper for 1976 TR 6 Triumph 6
J MGB 1976 mgb backfire MG 5
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
R Spitfire 1976 spitfire wiring harness Triumph 2
