MGB 1976 MGB Roadster for a patient.
Platinum
A pal has brought his MGB here for me to get running, I've worked on it in the (distant) past. First issue was the half-and-half mixture in the fuel tank: half fuel, half WATER. Drained that all out, threw a bottle of HEAT in there followed by a half-dozen gallons of actual gasoline.
Thing has a Cannon intake with an IDF/DGV Weber mounted,that came off and got a total going-thru. Had to replace the float valve. YUK!!! green and gobber'd up mud. Manifold had a frog pond in the base under the carb, too. NO idea how they got it to run long enough to get it here!
Now looking at the dizzy, it has a coating of "frosting" of some fuzzy funky description. Looks to be corrosion.Don't let 'em sit for months outdoors!
drooartz
It is amazing how much abuse they will take and still run at least a little.
Heck, I found out that an MGB will run (sorta) on only one cylinder -- when you forget to replace the 1-3 leads after doing an oil change for instance. Not that I'd ever do that.
aeronca65t
I have the same manifold and DGV carb on my '69 MGB. I despise the way it looks, but it actually runs OK.
I bought a set of HS4s (+ MGB manifold) for cheap, but I think I'm going to fit them to the 1275 on the race car instead.
I know what you mean about pond scum in the carb. I bought that '73 Midget about a year back and the DGV in it was filled with greenish goobers. I pulled the 1275 out (also using for race car) and dropped in a 948.
Cleaned out the DGV plus swapped the gas tank (it was unbelievable) and runs fine (for a sub-liter car with a goofy carb).
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
R MGB 1976 MGB restoration question MG 11
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
J MGB 1976 mgb backfire MG 5
S MGB 1976 MGB Runs Hot MG 23
Y MGB 1976 MGB for sale MG 0
B MGB replacing 1976 MGB ignition MG 1
G MGB 1976 MGB Sebring Valence Kit MG 9
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B TR6 TR6 1976 Clutch Choice Question Triumph 3
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
K 1976 BMW 530i Other Cars 3
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
D TR6 1976 TR6 Fuel Lines Triumph 7
D TR6 1976 TR6 Rebuild Triumph 11
M TR6 1976 TR6 Ignition problem Triumph 6
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
J TR6 Need front bumper for 1976 TR 6 Triumph 6
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
S TR6 Paint in a 1976 TR6 Triumph 8
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
R Spitfire 1976 spitfire wiring harness Triumph 2
Thor Can the 1976 plus radiator fit 1975 midget & Spridgets 7
