MGB 1976 MGB Runs Hot
ScotStern
Member
My problem is as follows:
When I am on the freeway....no problem. The cars runs with the needle on the "N".
When I am in traffic or just ideling the needle is higher...around a needle's width away from the "H".
The radiator is farily new and the coolant was just changed. Outside tempature is around 75 degrees.
Any thoughts?
Scot Stern
1975 and 1979 MGB
tony barnhill
Great Pumpkin - R.I.P
First, MG's didn't run hot from the factory....there's nothing inherently wrong with the basic design - its just been used for 30-something years...here's a run down of things to do/check:
1. Backflush the block - if that entails removing the freeze plugs, so be it.
2. Replace all the hoses - they're probably weak on the inner walls after all these years
3. Remove the heater core & flush it (oh, replace those hoses also)
4. Check the operation of the heater control valve
5. Thermostat
6. Are the fans operating properly?
7. Water pump - is it still doing everything its supposed to? If its old, replace it.
8. If your car had it originally, is the mud guard still between the radiator & front of engine
9. If your car has a complete radiator support panel, is the foam still between the radiator & it? Is the rubber still attached to the top of it?
10. Did I mention the radiator cap? No, replace it.
Basically, you want to ensure every piece of the cooling system is working as designed....
RF Thom
Scott
Sound like you have a water pump problem. Check the slip distance on the pump - that's the distance from the impeller blades tips to the angled face. It should be 0.012" max. If it's larger than 0.012" then at low speeds the coolant is lazy and flows around the impeller blades rather than going out into the block - thus low or no flow with resulting overheating. At higher speeds this slip as a protion of overall flow is reduced thus temperature returns to normal range. I discovered this condition by accident. A client had his engine overheat while idling pumping heating oil and crack the block. We put another engine in the vehicle - same thing. "What is similar and what is different" - as we were transferring parts from engine to base engine. We took the pump off and sure enough he had replaced the pump [leaking seal] the week before at a different repair shop out of town where the breakdown occurred. I put the pump on the bench and with a socket over the pump shaft reset the impeller to the 0.012" spec. - the truck now runs cool irrespective of engine speed.
Regards, Bob
jaybird
We've had the same issue with Emma. Only she runs HOT all the time, 1/8" from H. Even in the cooler weather, she runs just past the N. Radiator was pressurized and flushed, all hoses changed out, dahubby fabricated a mudguard/pan, put a new radiator cap on, and we changed from a 185 to a 160 thermostat. Didn't solve the issue. We just replaced the water pump yesterday. IF that doesn't help, we'll flush the block and heater core.
tony barnhill
All the 'bandaids' that people do to stop an overheating problem usually exaccerbate the problem down the line....you don't need extra electric pusher or puller fans bolted through the radiator, you don't need larger radiator, you don't need to drive without the thermostat....all you need to do is get your cooling system in the same working condition it was in when the car was new...
...I don't have overheating problems!
Sorry, rant over.
jaybird
I have an oil cooler here that we intend(ed) to put on Emma. Should we still go ahead and do that, or wait to see if the problem's solved with the water pump and/or flushing the block and heater?
tony barnhill
Did Emma come originally with an oil cooler? If not, why do you need one now?
jaybird
Umm, because a guy in the club (several) said it might help. And because a guy gave us one?
I get your point. We should give the oil cooler back, huh?
tony barnhill
No, install it if you want...it hangs upside down under your radiator panel...it'll keep the oil cooler...however, in Illinois winters, it might keep it so cool that your engine never warms up!
jaybird
Perhaps we should wait and see what the water pump does. In our winters, overheating shouldn't be an issue, wasn't last winter.
Oooh, forgot to tell you. That gas tank in Binabox had 5 or 6 gallons of gas in it. We drained it out today. I was amazed. There was no residue or sludge in it, it wasn't muddy or murky. Looked like it was just pumped. Even the last few drops. I wasscared to look what might have come out of there!
So I dumped it in Emma.
/ubbthreads/images/graemlins/laugh.gif
tony barnhill
OOOOHHHHH...get some Stabilizer in there with that old gas....it might be good but why take a chance...also add a can of HEET.
jaybird
Gotcha.
/ubbthreads/images/graemlins/devilgrin.gif
R6MGS
[ QUOTE ]
Sorry, rant over.
[/ QUOTE ]
/ubbthreads/images/graemlins/iagree.gif It's amazing the lengths I've seen people go to stop an MG from overheating....I've actually never had any serious overheating problems(on a british car), but then this IS canada.
Guinn
Hi, Jay, One thing I learned in AF Instrument school: Whenever you have a consistent out of range reading, swap in a known good instrument if possible. Often this saves a lot of tinkering. Actually, I did learn a little more, but it has been a long time ago.
Guinn
jsneddon
[ QUOTE ]
Guinn
[/ QUOTE ]
Agreed.
but since a known good instrument probably isn't at your fingertips....
Before you do anything else: Take off the radiator cap while cool. Stick a good thermometer in the radiator. Let the car warm up and see what the temp reads. I'm not sure on a B but N on a TR (a "real" car) /ubbthreads/images/graemlins/smile.gif is about 180 - 185. Or go down to Radio Shack and get a fancy IR spot thermometer for 50 or 60 bucks and point it at the thermostat housing.
jaybird
Can I use my kitchen thermometer? It's 35 degrees right now, surely you don't mean check it when it's THAT cool? Should I run her 10-15 minutes then let her cool?
DART
JB-I think the cool part had to do with safely taking the cap off. Any thermometer that reads to 212 should work, I should think. And I don't quite buy Tony's assumption all LBC's were properly engineered to run cool in hotter US climes. An electric fan addition is almost mandatory in a Dart. /ubbthreads/images/graemlins/cheers.gif
jsneddon
[ QUOTE ]
[/ QUOTE ]
By cool I mean don't open the cap off when the car is at temp. You might get a nice Glycol Facial.
jaybird
Gotcha. But opening it right now won't determine anything. I'll take her for a drive this afternoon, let her sit a bit, check her temp and report back.
Nunyas
JB: I believe the way to do this is open the radiator. Start the engine and let it idle. Place the thermometer in to the radiator cap hole and watch the temp. Let the car keep idling until the in car guage reaches the point that you normally see it when driving around, assuming it doesn't start boiling before then (it shouldn't).
The temp should rise relatively quickly when the thermostat opens to let the coolant flow.
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
R MGB 1976 MGB restoration question MG 11
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
J MGB 1976 mgb backfire MG 5
Y MGB 1976 MGB for sale MG 0
B MGB replacing 1976 MGB ignition MG 1
G MGB 1976 MGB Sebring Valence Kit MG 9
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B TR6 TR6 1976 Clutch Choice Question Triumph 3
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
K 1976 BMW 530i Other Cars 3
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
D TR6 1976 TR6 Fuel Lines Triumph 7
D TR6 1976 TR6 Rebuild Triumph 11
M TR6 1976 TR6 Ignition problem Triumph 6
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
J TR6 Need front bumper for 1976 TR 6 Triumph 6
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
S TR6 Paint in a 1976 TR6 Triumph 8
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
R Spitfire 1976 spitfire wiring harness Triumph 2
Thor Can the 1976 plus radiator fit 1975 midget & Spridgets 7
