Starting problem .. and a burning problem??
Pizzi348
I have a couple of problems with my AH 100. I thinking the first problem is a starter.
My car fires right up. I can drive it as far as I want (I went 40 or so miles). When I turn the car off, it has trouble starting again. It sounds like a dead battery. If I wait 20 or so minutes ... it will start up again?? The battery is brand new.
Second problem ... I think my brakes get stuck?
Yesterday, I was driving back to my house (about 20 miles or so) very hot and probably shouldn't have had the car out, but I got stuck because of the first problem I mentioned. Anyway, it was about 94 out. The car did great, didn't over heat at all, except I thought my sneaker was melting! The last few miles started to smell like burning rubber. I got out the car and smoke was coming out for the rear wheel wells. The brake pedal felt kind of dead. Like I only had to push it in an inch instead of the regular three inches to get the car to stop. I thought maybe the e-brake wasn't disengaging properly, but really have no idea. Anyone know where I should start looking?
Thanks! Matt
abarth69
I think your starting problem if you do a search you will find lots of info on. I think it has to do with your ground.
Cheers
Mark
roscoe
I'm not going to guess what your starting problem is. I would think a bad ground would not "go away" after 20 minutes. Perhaps if your battery is marginal or not charging during driving, when you are trying to start with the engine really warm and compression just a bit higher than when it is cold, that it is just too much for it to crank. I guess that is a guess. Check the voltage drop when you crank the engine.
The brakes need to be looked at and checked for adjustment. There is one brake adjuster on each rear wheel and two on each front. Jack the wheels one at a time and make sure they spin freely. Do the adjustment per the shop manual. Turn the adjusters until the brakes grab and back off a notch until they spin. You may have something binding or broken inside the brake drum, or your hand brake may not be releasing, as you suggest. I'd pull the rear wheels and brake drums just to make sure everything looks ok. You can get a good look at the hand brake mechanism by the right rear wheel when you have the wheel off. The drums are pretty easy to get off and you could have a large amount of dirt or brake dust inside the drum.
G
gblawson
If the above doesn't solve the brakes 'holding' on, pull the rubber brake hoses connecting your brake lines to your wheels (and the one up under the rear end)... if they are old original, or just old, they can be like a one way valve...let you apply, but don't release!!! Happens all the time!!!
shorn
Agree with the above. The old rubber brake lines can deteriorate on the inside and collapse. Brake fluid gets pushed through the line when the brakes are applied, but doesn't return when the brake pedal is released. Might as well change the two in the front also, if they are old.
Jerry
I had a starting problem just like yours and it was the solinoid. Worked well when cold but not when hot.
Jerry
P
Pizzi348
Thanks Jerry .. that was my first thought.
stever
I vaguely recall that about 25 years or so ago I had a similar situation to yours with the starter. My recollection is that a bushing in the starter itself had become so worn that the shaft bound up when attempting to start - an intermittent problem, but very frustrating. I had the starter "rebuilt" and that took care of it. If the problem persists after changing out the solenoid as suggested earlier, you could have the starter itself looked at.
bob hughes
Hey Matt
I had an intermittent problem, a bit like yours. Turned out to be a the wire connection from the coil to the dizzy, the end connector had been hanging on by a wire thread, when cold ok, when hot no go. But failure occured on route without stopping. Replaced with new and no problems since.
Bob
TimK
I have had the left rear brake cylinder cock at a slight angle when putting on the brakes and not release. I have had to back off the brake adjuster, remove the drum and push the wheel cylinder back in place. I just ordered new locking plates to see if that will cure my problem.
pan
Hi Matt,
TimK is referring to the later type "5 stud" Hypoid rear axle, which has a sliding cylinder.
The earlier 100 has a "4 stud" Spiral Bevel axle. These have a fixed brake slave cylinder. There are cams and a sliding mechanism that operates the hand-brake (park-brake)which can freeze up and hold the shoes against the drum.
Which does your 100 have?
P
Pizzi348
Hi Pan
My garage is the process of being built so I have to wait until it's done before I get it on a lift. Do you know year they changes to the 5 stud?
Thanks,
Matt
Lutz Kramer Problem starting the cold engine Austin Healey 16
S BJ8 Hot Starting Problem Austin Healey 25
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
D frogeye starting problem Austin Healey 2
tahoe healey starting problem Austin Healey 10
J Spitfire Hot starting problem, 78 Spitfire Triumph 7
mgbmedic Wedge Triumph TR7 Starting Problem Triumph 4
roofman Spitfire 75 spitfire starting problem Triumph 6
B TR6 TR6 starting problem Triumph 24
C MGB Wierd starting problem - 77 mgb MG 4
R odd starting problem Spridgets 1
T Novice seeking advice on starting problem Spridgets 32
R Hard starting problem Austin Healey 2
LastDeadLast Help me with a starting problem Triumph 17
R Starting problem MG 6
R Cold Starting Problem for a BJ7 Austin Healey 4
B Healey starting problem Austin Healey 19
B Starting Problem Spridgets 6
catfood Starting problem solved, but... Austin Healey 1
W Starting Problem Austin Healey 4
M Intermittent starting problem Jaguar 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
