Hard starting problem
Ray Smith
Still having hard starting problems with the BJ7. Have adjusted timing and checked plugs for proper color. The engine does not seem to be running lean if plug color is a good indicator.
The engine starts with just a touch of the starter button when the engine is warm. It will also start easily if I prime a carb with a little bit of gasoline. Could the fuel pump be the culprit? How many psi should the pump produce?
I also notice that the front carb body has moisture condensing on it when the engine is running and warm. This does not occur on the rear carb.
Ray
Terry_Geiger
Is everything working with the choke linkages? It may be a problem with the choke linkage being unable to pull the jets down to enrichen the mixture enough to crank cold.
S TR2/3/3A TR3 Hard Starting Triumph 4
D Hard Starting Austin Healey 14
R winter hard starting BJ7 Austin Healey 16
P TR6 TR6 hard starting Triumph 24
S Hard starting on Webers from cold Austin Healey 12
P TR6 Follow-up to hard starting Triumph 4
P TR6 hard starting Triumph 23
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
R hard starting Austin Healey 8
T TR2/3/3A Hard starting when hot Triumph 9
B Hard starting 1960 AH 3000 BT-7 Austin Healey 6
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
S BJ8 hard starting when warmed up Austin Healey 11
J Spitfire 78 Spitfire hard starting Triumph 2
Thor Suggestions for hard starting 1500 when cold Spridgets 5
roofman Spitfire Hard starting Spitfire Triumph 12
Stewart Backfiring stalling and missing hard starting MG 5
D MGA MGA hard starting sometime backfires MG 2
E hard starting-engine quits Spridgets 14
W Hard starting Jaguar 5
W Hard starting in the cold Austin Healey 4
txtr3 TR2/3/3A TR3 hard starting, but has been running ok Triumph 11
G Hard starting, but then runs fine MG 6
S 57 T-Bird hard starting when hot Other Cars 5
J Hard Starting vs Fuel Austin Healey 3
W hard starting when hot MG 7
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Hard start questions.... Triumph 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
