hard starting when hot
WLJ
Member
I have a 75 MGB with a stomberg carb that has a manual choke conversion. This car starts great when cold and runs good when driving. My problem is when I go to start the car after a run it takes a lot of cranking to get it going.The choke is completely off and it has recent plugs,wires,coil,condenser,dis. cap,air filter,points,and fuel filter.I have had this car for 18 years and recently rebuilt it but did not touch the carb except for the manual choke.It almost seems like a gas vaporizing problem. Any ideas would be appreciated.
Thanks, Warren
aeronca65t
I'd go back and check the choke cable.
Be sure that the choke is really closing off the enrichment mechanism fully. If the carb was partly disassembled anytime recently you need to be sure that everything in the choke (gaskets, the piston, levers, etc.) was put back correctly.
And be sure that the choke arm is not "creeping out" due to vibration from running...have a look at it after shutting down.
After that, I'd check the floats and needle/seat in the float chamber.
Then the main piston diagphram.
I'll assume that the air filters are clean.
Once-in-a-while it's also good to check the nuts that hold the intake manifold to the head. Since this is a side draft setup, it has a tendency to get loose with time (and cause "funny" carb-like problems).
If you still have problems, you may want to check valve adjustment...a too-tight condition can cause poor hot starting.
[ 10-02-2003: Message edited by: aeronca65t ]</p>
tony barnhill
Great Pumpkin - R.I.P
also check to see if your butterfly is weighted...many of us have modified our Strombergs over the years by superglueing a weight on the bottom side of the butterfly to ensure it does close completely - believe that was also a factory recall item to accomplish....I'll have to check my dealer recall/tech sheets.
...with some manual chokw setups, the choke isn't dialed in properly & closes when cold but not completely when hot...twitch the spring a bit looser & see what happens
W
WLJ
Member
Thanks for the ideas I am going to check these out as soon as I can.The choke vibrating back on sounds like a possible explanation.If the diaphram was bad would the car start at all or just run badly?
Warren
Obtong
Warren, have you changed the kind of gas or lead additive recently? Also, I was wondering if you have a case of vapor lock. Perhaps a fuel line was rerouted when you rebuilt the car and the fuel line now gets too hot.
Just a thought...
Dom
W
WLJ
Member
Dom, The problem happens with all grades of gas.The fuel line is run in the same place it was before the rebuild and I only use one kind of lead additive.I did check the diaphram and made sure the choke was staying off,both are okay.The car is working really well except for this little problem.I am going to check the other suggestions as I have time.
Warren
T TR2/3/3A Hard starting when hot Triumph 9
S 57 T-Bird hard starting when hot Other Cars 5
S TR2/3/3A TR3 Hard Starting Triumph 4
D Hard Starting Austin Healey 14
R winter hard starting BJ7 Austin Healey 16
P TR6 TR6 hard starting Triumph 24
S Hard starting on Webers from cold Austin Healey 12
P TR6 Follow-up to hard starting Triumph 4
P TR6 hard starting Triumph 23
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
R hard starting Austin Healey 8
B Hard starting 1960 AH 3000 BT-7 Austin Healey 6
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
S BJ8 hard starting when warmed up Austin Healey 11
J Spitfire 78 Spitfire hard starting Triumph 2
Thor Suggestions for hard starting 1500 when cold Spridgets 5
roofman Spitfire Hard starting Spitfire Triumph 12
Stewart Backfiring stalling and missing hard starting MG 5
D MGA MGA hard starting sometime backfires MG 2
E hard starting-engine quits Spridgets 14
R Hard starting problem Austin Healey 2
W Hard starting Jaguar 5
W Hard starting in the cold Austin Healey 4
txtr3 TR2/3/3A TR3 hard starting, but has been running ok Triumph 11
G Hard starting, but then runs fine MG 6
J Hard Starting vs Fuel Austin Healey 3
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Hard start questions.... Triumph 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
