57 T-Bird hard starting when hot
shorn
OK, I have a 64 BJ8, but my other car is a 1957 T-Bird, which is really hard to re-start after it has warmed up. I put a lower temp thermostat in it, and it runs cool enough unless it is just idling in traffic. Then it tends to run hot. The engine temp also goes up a fair amount right after the engine is shut off. I suspect the gas is actually boiling out (evaporating) from the carb. The carb has about a 3/8 inch spacer (insulator) between the carb and the manifold. So I think I know the problem. I just don't know the fix. Ideas???
RVMAN
Is is a mechanical fuel pump or electrical? If mechanical you could "help" it with a low pressure electrical to provide a fuel supply without having to crank the mech. pump during the fuel starved hot starts.(i.e. either add or replace your mechanical pump with elec. like our healys have.
S
shorn
yes it is mechanical. so I suppose that requires me to grind on the starter to prime the carb. I will see if an electrical fuel pump is available. just hope it's not an S U or lucas. I don't need more trouble.
thanks,
skip
sammyb
Make sure that the choke works properly. If the car is warm and the choke isn't fully off, it won't start.
I assume that the starter is cranking well?
Also, make sure your fuel lines are protected from hitting exhaust manifolds and other really hot places. This could also be a problem that when the car is turned off, the gas stops in the line and actually begins to get wicked hot, making it vaporize before getting to the carb on restart.
Bruce Bowker
I had a similar problem and after much searching of the fuel system found that it was the coil getting too hot and failing.
Easy to check if you are getting spark and that elimnates that area at least.
90 XJ-S
Does it still have that crazy "inside out" holly? If so, you probably are right about boiling the fuel out of it. The electric pump should fix it. Just remember, when you search for one, you want one for a carburated engine (not FI)
Mike
C Rare Bird - Hawke DL11 [circa 1973] Racing 3
Banjo Swiss-army knife T-bird Other Cars 6
rick_ingram MG2006 - Early Bird Registration ends SOON! MG 2
rick_ingram MG2006 - Early Bird Registration MG 3
jaybird The 'bird's Tech Tip #17 MG 42
Mickey Richaud Another Rare Bird MG 7
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
S TR2/3/3A TR3 Hard Starting Triumph 4
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Hard start questions.... Triumph 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
Healey Nut Good hard top on flea bay Austin Healey 6
W Spitfire Hard Top rubber Triumph 5
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
D General TR Hard lessons learned Triumph 4
Rut TR6 Hard top finisher Triumph 1
Rob Glasgow Hard Top Rubber Seal Austin Healey 3
1 MGB 1966 MGB hard shifting into 3rd MG 1
TomMull Wanted TR3 Hard Top Triumph Classifieds 11
RAC68 Top Frame, Hard to Weld Austin Healey 13
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
2billydavies TR2/3/3A runs excellent but starts hard after use Triumph 8
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
D Hard Starting Austin Healey 14
aero3113 3000 with clear hard top?? Austin Healey 11
S This Austin Healey video had me laughing so hard I cried. Austin Healey 5
J For Sale Austin Healey Hard top Austin Healey Classifieds 1
D BJ8 pulls right on hard braking? Austin Healey 4
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
R winter hard starting BJ7 Austin Healey 16
