Suggestions for hard starting 1500 when cold
Thor
Have a question. I have no difficulty starting my 1500 when its above 45. When it drops below that forget it. I can't get it started even if I use starter fluid and have the choke out all way. Does anyone have ideas as to why it's so difficult? The battery is new by the way. The engine does turnover very slowly when cold but I can't even get it to catch. Would I need a more powerful starter, could it be the timing? Thanks for any suggestions.
aeronca65t
There are better (gear reduction) starters but a standard unit with a new battery should do fine.
If it's cranking slow all the time, what oil are you running? This time of year, 10W-30 is fine in your area. Heavier oil will lead to slow cranking, even with a good battery (you have good cables and a good ground to the frame and engine, right?).
Yes, timing matters for good starting.
Also, check your spark plugs. If any doubt, replace them.
Look at cap and rotor. If they're burned or pitted, you should probably replace.
Carefull remove all sprak plug wire and check resistance using a volt-ohm meter. They should all be about the same value. if they vary a lot, new wires are in order.
Does your car have points or the electroic ignition? The early electronic systems weren't that good and some folks convert to the Pertroiix electronic ignition or even old-fashioned points and condensor (either would be an improvement over the early electronic system). If your car has points, check the gap and replace if they are burned or pitted.
Is your fuel pump filling the carb? Remove the line to the carb and see if it pumps fuel when you crank the engine (for just a few seconds...and have someone catch the fuel in a plastic container. You don't want gas all over the place. Dangerous.) If the pump is shooting out spurts of gas, you might still have a clogged carb or sticky float. Either way, the carb can be taken apart and cleaned to correct this. Many folks do not like the stock ZS carb (I'm not a big fan of them myself), but they can be made to work OK if they are clean internally.
G'luck!
Hairyone
my 1275 sometimes turned over slowly, again new fully charger battery, new electrics & heavy duty cables from battery to starter & an extra cable from chassis to engine block. The Lucas starter I took out, cleaned, checked brushes, all looked well & bench tested OK.
I got fed up with the lucas starter & brought a reduction gear starter. mutts nuts. no problems now.
G
G'luck!
+1 it should light w/ ether easily.
Thor
Thor
Thanks everyone for input and suggestions. I forgot to add I am running dual SU-4 carbs and its a manual choke. Also have Pertrox ignition. Running 10w-50.
I checked the spark plugs. Pretty black, so I cleaned them up. When I idle the car for any length they get that way but as soon as I take her out and run her a while usually clean up by self. I was going to take it out today as it was 60 degrees but when went to start it the starter just whirled and didn't kick the motor over. Had to pull the starter and found that the pinion and sleeve were not descending. I don't think the problem is related to the initial problem just another one added to the list. Ugh!
Well I might be in market for starter. Anyone fit a reduction starter into 1500? I checked out a couple of internet places and saw a place called "British Starters.com" They state they have "expertly machined and modified" reduction starter to work in the MG Midget. Anyone used them or can they recommend someone?
Thanks
I Bugeye valve rebuild suggestions Spridgets 8
D Shop lighting suggestions. Restoration & Tools 8
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
catfood Looking for suggestions - ignition issue Austin Healey 6
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
Bob_Spidell Rebuild Performance Suggestions Sought Austin Healey 8
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
RAC68 Gear Reduction Starter Infor and Suggestions Requested Austin Healey 11
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
I General TR Mold clean up suggestions Triumph 4
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
M suggestions on vendor Rear brake rebuild Spridgets 15
DerekJ Healey Blue Paint - suggestions Austin Healey 23
J General TR D Type overdrive not working need suggestions Triumph 5
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
I TR6 suggestions for brake LED bulbs Triumph 13
dcoplan Tires rubbing on frame - suggestions? Spridgets 2
I TR6 Muffler suggestions? Triumph 6
HealeyDave Car transport company suggestions needed - winter/midwest/USA Austin Healey 2
M Overdrive parts source suggestions Austin Healey 4
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
S TR6 Suggestions: cylinder head won't release from block Triumph 10
Zimmycobra Trans problem. Looking for suggestions. Triumph 10
S Any suggestions on where to start? MG 7
D TR2/3/3A Suggestions needed for TR3 pricing Triumph 10
M TR4/4A 67 TR4A hasn't run for 10 yrs+... suggestions? Triumph 11
TRMark Brake pad suggestions Triumph 16
I Suggestions for bugeye headlights Spridgets 21
M suggestions for brake system Spridgets 9
RAC68 Paint & Design Suggestions Triumph 4
Andrew Mace lacquer primer removal suggestions Triumph 4
I LED tail light suggestions? Spridgets 22
G TR6 Radio suggestions for fitting to TR6 Triumph 3
hondo402000 suggestions on Ignition coils Triumph 22
I Suggestions for tach gear rebuild? Spridgets 8
J rear brake rubbing, need suggestions Triumph 12
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
I Adhesive suggestions? Spridgets 4
I Wax, rubbing compound suggestions Spridgets 10
AngliaGT Subaru Wagon Suggestions? Other Cars 8
I Suggestions for new Bugeye soft top? Spridgets 3
TomMull carburetors not pretty, cleaning suggestions neede Triumph 13
RAC68 Suggestions – LED Project Austin Healey 24
O Suggestions.. Austin Healey 8
