BJ8 Hot Starting Problem
Scot
Guys, I'm having a hot start problem with my BJ8. It seems she wants to start cold soaked with a fully charged battery, but after it gets up to operating temp and is shut down for a few minutes it can't turn over. Obviously have gas and spark, but wondering if this could be an electrical problem like a coil or condenser or the related wiring. Everything looks tidy when I checked for these things. Anyone ever have a problem like this?
why
If the starter makes a groan as if trying to turn but never gets going, tap it with knock-off hammer, sometimes just pushing clutch in and out will do the trick, seems to be a magic window of under bonnet temp where this happens. Sometimes cleaning where ground strap attaches to fitting for terminal, or any other ground contact spot will do the trick, for a while. oh, cleaning every contact in trunk cut-off switch or when main lead connects starter, or even lead involved with solenoid, Jay, '65 3000
Keith_M
Guys, I'm having a hot start problem with my BJ8. It seems she wants to start cold soaked with a fully charged battery but after it gets up to operating temp and is shut down for a few minutes it cant turn over. Obviously have gas and spark but wondering if this could be an electrical problem like a coil or condenser or the related wiring. Everything looks tidy when I checked for these things. Anyone ever have a problem like this?
I think we need a clarification. Are you saying it won't start or that the starter motor can't turn the engine over? Two very different problems.
bob hughes
Assuming that it does turn over, try checking the wire from the coil to the side of the dizzy, or even just substituting it with a temporary. If you have sparks, this may not cure the problem, but it could be intermittent sparking as this wire has a tendency to break near a connection and then it is hit and miss. Once the engine gets cold, does it then start up again?
:cheers:
Bob
S
Scot
Keith the starter motor runs fine but the engine wont turn over when hot. Bob once the engine is cold soaked again it starts right up. I replaced this wire once with hardware store materials years ago so perhaps ordering it from a vendor and replacing might fix the problem?
Healey Nut
Remove the wire between the solenoid and the starter and solder the crimped connections directly to the copper core . You may have a high resistance joint that when the engine heat heats up the cable the starter doesnt have the balls to turn the motor over due to high resistance .
Failing that put a gear reduction starter on it and solve all your problems .
bob hughes
Scot
That wire is part of the harness set up so can not be bought as a separate, Just pull the connections and wire in a new length between coil and dizzy, I travelled for years with just this quick fix before I rewired the car, so that should not be the cause of your problems - unless the wire is broken - usually near the connections.
:cheers:
Bob
BOBBYR
Hi Scot, I was wondering how you made out with your hot starting problem. If your still having the same problem , I might have a suggestion .
Regards, Bobby R
S
Scot
Hi Bobby, I still have the same issue but have been trying to work thru the excellent suggestions on this thread. I would welcome your input.
BOBBYR
Hi Scot, give a little run down on what problems you are having now and what have you tried to correct this .
S
Scot
Actually still having the same problem as originally posted...tried replacing wire between the coil and dizzy.
Keith_M
Hi Scot,
I kinda lost track of this thread. Let me see if I have it straight. When then engine is hot, the the starter motor can turn the engine but the engine won't start. You've replaced the coil, but it doesn't help. It sounds like vapor lock or the fuel boiling in the carb bowls to me.
Keith
S
Scot
Yes when the engine is hot the starter will turn the engine but it wont turn over and start. I did not replace the coil yet as it is pretty new but I may try that. I have a glass in line fuel filter connected as the fuel enters the carbs. It never really had this problem before but if the fuel is boiling or vapor lock how can I correct it? I have had the heat shield out once and replaced the material on it.
Keith_M
Once the engine is off, all the heat just builds up under there. I don't know of any way to cure the problem short of opening the hood and allowing the heat to escape. Mine is always hard to start after it's been running hard and then shut down, but it doesn't sound quite as bad as yours. The car doesn't quit or run poorly if you sit at a stop light for a while does it? If so, adding a 5-bladed fan will help move more air through the engine compartment and keep temperatures down. Doesn't help if you turn off the engine, though.
drambuie
First check your point gap and then ignition timing, set your timing light to 15 degree advance and line up your timing marks at about 700 to 800 rpm. Also could be faulty tune up parts as well as we are getting so much junk from the major distributors these days! Bad points, condensers, rotors and caps. Do these simple things first.. A engine out of time can really heat up a very quickly and result in very hard starting.
S
Scot
Hi All, Just an update on my hard starting problem when engine hot...I have replaced ignition wire between dizzy and coil, replaced coil itself, replaced fuel filter, cleaned grounds and have checked point gap and timing. Problem persists. Any other suggestions welcome! Thanks...
C BJ8 Rebuilt Engine and Carbs - Vapor Lock and Misfires when hot Austin Healey 7
Wana BJ8 Doesn't want to start when hot Austin Healey 11
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
