BROKEN ROD BOLT has any body had one?
ken941
Some people think they should only be used once I’m in the process of rebuilding my engine and was wondering what other peoples thoughts are on this. I rebuilt an engine 30+ years ago with help from my dad how was an aircraft mechanic he never mentioned that was what should be done. I can see it if you are racing but for street I’ve read about them stretching ect Also read some of the aftermarket one aren’t as good as the originals Haynes manual doesn’t mention it. So has any body had problems with reusing them?
TR3driver
Great Pumpkin - R.I.P
I like to check that they will spin easily into the rod all the way down. If they are stretched, it will be in the threads and the threads will bind.
Never found a bad rod bolt, but I have found a few bad head studs & wheel studs.
But that's on TR3 motors, you didn't mention what you are building. Might be different for the other Triumph engines.
Brosky
If you have a TR6, this is a known point of weakness. After 30 years plus, there is no shame in spending money to replace the bolts with stock units. You don't have to get expensive with ARP's, the stock will do just fine.
I've seen a couple of blown TR6 engines with a rod bolt broken but didn't get the history when I got the car. Average driving shouldn't be a problem but if its a second rebuild with high mileage I would think twice about it. As Randall said, if they spin good they're probably okay.
Marv
Actually, these days with people giving away stuff on the internet, you can buy ARP rod bolts almost as inexpensive as stock replacments. I'm finishing a rebuild on a TR6 engine right now and used the ARP rod bolts, which I mostly use in all my rebuilds. Heck on MG 1275s, ARP rod bolts are actaully cheaper than stock replacments from all the popular LBC vendors, it pays to check this out if repalcing rod bolts.
glemon
DNK said:
Ken, Post your car in your signature
OK, that prompted me to figure out how to do that, good idea, this is a test to see if it worked, sorry to interrupt, back to your bolt talk...
DNK
Didn't work
What you need to do if you change something in your profile is close the program down, just as if your updating windows or the like
glemon
It did work, except I was thinking avatar or the little pic up top, which it looks like I successfully added, not the signature line, I now realize that was not what was said, or meant....
D TR2/3/3A repairing broken hardboard seatback Triumph 8
Bayless How to repair broken vent window studs? Spridgets 1
M TR6 1973 TR6 - broken choke cable Triumph 6
P Broken Overdrive Switch in Gear Knob Austin Healey 14
AH67AH Broken Shock Mounts Austin Healey 23
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
K What is this broken part in my transmission/OD? Austin Healey 6
tahoe healey Broken Spokes Austin Healey 8
H broken sway bar link - again Austin Healey 8
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
KVH General Tech Clutch Fork and Broken Pin Triumph 8
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
B wire wheels and broken spokes Austin Healey 19
I TR6 Broken front suspension bracket Triumph 3
D TR4/4A broken trans fork pin Triumph 14
mcmillal TR4/4A Broken Vertical Link Triumph 17
D BJ 8 Side window broken - Help !! Austin Healey 9
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
C TR6 Broken Throttle Shaft Triumph 4
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
B TR4/4A TR4A Head off for broken manifold stud - What else to do ? Triumph 13
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
P BJ 8 broken hood frame screw Austin Healey 6
TomChar TR6 '74 Clutch & various broken bits Triumph 20
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J TR2/3/3A Broken pinion gear tooth, I am sad! Triumph 2
A Broken Axle Question? Spridgets 11
Gliderman8 Help with restoring broken aluminum logo badge Restoration & Tools 6
J Need some expertise, broken exhaust maniford Triumph 9
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
K Anyone experience a broken crosshaft pin.... Triumph 6
H broken sway bar link Austin Healey 13
K TR2/3/3A Crossshaft broken taper pin removal? TR3 Triumph 5
P broken oil cooler fitting MG 1
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
nevets Points failure - broken cam follower Austin Healey 3
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Westfield_XI Three broken spiders later..... Spridgets 54
tahoe healey broken spoke Austin Healey 12
V Help: key broken off in ignition! Triumph 18
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
B High Torque Starter Broken mount Austin Healey 1
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
middie Is this sender wire broken?? Spridgets 2
davester Help needed...broken exhaust manifold stud MG 15
jvandyke hood [bonnet] release broken cable Spridgets 34
M Broken Ball Joints Spridgets 14
