BJ-7 Rear Shock Link
gonzo
Is this the correct orientation of the rear shock link for early BJ-7. Link's "up" position in relation to shock arm does not look correct. Below pic is from internet. Links on my car on in "down" position, but need confirmation. Thanks all, GONZO
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
M TR2/3/3A TR3 rear shock link question Triumph 4
JohnnyMead TR2/3/3A Tr3 Rear Shock Link Triumph 4
J Rear Axle Shock Link Help Austin Healey 6
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
H Rear Shock Removal Austin Healey 5
S TR2/3/3A rear shock arms and links Triumph 4
John Turney Left Rear Shock Mount Austin Healey 5
T TR2/3/3A How important are matching rear shock links? Triumph 9
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
GTP1960 TR2/3/3A Rear shock linkage orientation? Triumph 2
S TR2/3/3A rear shock links Triumph 2
mt10flyer TR2/3/3A Rear shock mounting plate Triumph 28
D TR6 Rear Shock Refurb Options 76TR6 Triumph 15
F Rear shock conversion and correct SPAX? Triumph 1
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
regularman Anyone else do their own rear shock conversion? Spridgets 15
C TR2/3/3A Rebuild of rear shock for 58Tr3a Triumph 6
S TR6 tr6 rear shock part number ??? Triumph 5
J rear shock picture; Surely this can't be right? Spridgets 8
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Reh Spitfire GT6 rear shock to spit mount Triumph 3
KVH Rear Lever Shock Help Triumph 6
M rear lever shock? Triumph 21
D Rear Shock Absorber Links Austin Healey 7
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
bigbadbluetr6 TR6 TR-6 rear tube shock conversion question Triumph 20
Z Early BN1 Rear Shock Bolt Dimensions Austin Healey 10
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
K TR4/4A TR4A rear shock conversion kit question Triumph 3
6 Need help with BJ8 rear shock position Austin Healey 2
6 BJ8 Rear Shock Installation Austin Healey 1
mountainman TR2/3/3A TR3 Rear Shock Absorber Fluild Triumph 3
tahoe healey rear shock absorber Austin Healey 9
H TR2/3/3A TR3 Rear Shock Removal Triumph 6
angelfj1 TR5/TR250 TR250/6 Telescopic rear shock retrofit Triumph 2
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
hondo402000 rear shock rebuild Triumph 11
S Rear Tube Shock Converstions Triumph 17
T TR6 TR6 Rear lever shock rebuild: Triumph 3
Shinsen774 Replacement Tube Shock Rear-Advice MG 1
R Rear shock replacement for the KYB conversion Triumph 8
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
Dave Richards Rear Shock Bolts Austin Healey 6
S 1979 rear shock conversion kit worth it? Spridgets 10
W Rear Shock Removal Austin Healey 16
