Rear Shock Removal
HealeyNZ
Hi All,
I am looking to refresh the rear suspension on by BT7. The manual describes removing the shock absorbers as a simple 3 step process:
1) Remove the nut hold the shock lever to the link arm
2) Remove the bolts securing the shock body to the chassis
3) Remove the the shock from the link arm
Easy! Except I can't remove the lever from the link arm or if I undo the link arm nut the link arm from the chassis.
So in the attached image how to you actually separate the shock lever arm and/or the link arm?
Appreciate any suggestions.
Cheers
John
Deleted member 21878
i did the same thing last year. i think i used a tie-rod separator from Autozone. it looks like a big fork that is wedge shaped. couple of hits from a hammer and it came loose.
if i recall it was a bigger pain to get back in. lining up the bolts was kind of tough. i think the issue was the exhaust side. the other side you could get in and then rotate the shock up. had to fiddle around with it for a while.
John Turney
Nothing is a simple process on a Healey.
I found that removing the link and shock together was a bit easier. Then remove the link from the shock arm on the bench. The link to axle connection isn't tapered IIRC. There is a tube between the two ears on the axle.
Note when you put it back together: Make sure the axle is at the normal ride height relative to the frame when you tighten the link nuts. (Support the axle instead of the frame using jack stands.)
H
HealeyNZ
Thanks for those replies.
@DroneDog - The only separator I have it too big so will try to source a smaller one. That is slightly more challenging than it should be as here in New Zealand we are in 'Level 3 COVID-19 lockdown' which means I can't just pop down to our equivalent of AutoZone.
@John - I also own a Lotus so the Healey isn't always that hard! I like the idea of taking the whole link off but it won't budge either
Next plan is to source a smaller tie-rod separator and/or try the other side which would also have the advantage of not having the exhaust in the way.
I will report back then.
Thanks again.
John
H
HealeyNZ
Success! Well partial success really. Taking the advice that the link to axle wasn't tapered I:
1) Undid the rear 2 exhaust mounts and dropped the exhaust out of the way
2) Got a long rod that I could hold against the link bolt nut
3) Got a bigger hammer
A couple of cracks with that and it popped out. Have also ordered a smaller tie rod separator so hopefully when that arrives I can get the shock off the link.
The shock seems in a sad way, I can move the lever easily by hand with little/no resistance which I assume is not correct.
Cheers
John
John Turney
... The shock seems in a sad way, I can move the lever easily by hand with little/no resistance which I assume is not correct.
Cheers
John
The shock is probably empty of fluid. The only way it disappears is by leakage, usually through the seals on the shaft. Sounds like it's time for a rebuild or replacement.
H TR2/3/3A TR3 Rear Shock Removal Triumph 6
W Rear Shock Removal Austin Healey 16
B Rear Shock removal MG 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
S TR2/3/3A rear shock arms and links Triumph 4
John Turney Left Rear Shock Mount Austin Healey 5
G BJ-7 Rear Shock Link Austin Healey 2
T TR2/3/3A How important are matching rear shock links? Triumph 9
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
GTP1960 TR2/3/3A Rear shock linkage orientation? Triumph 2
S TR2/3/3A rear shock links Triumph 2
mt10flyer TR2/3/3A Rear shock mounting plate Triumph 28
D TR6 Rear Shock Refurb Options 76TR6 Triumph 15
F Rear shock conversion and correct SPAX? Triumph 1
P BUGEYE REAR TUBE SHOCK CONVERSION Spridgets 0
regularman Anyone else do their own rear shock conversion? Spridgets 15
C TR2/3/3A Rebuild of rear shock for 58Tr3a Triumph 6
S TR6 tr6 rear shock part number ??? Triumph 5
J rear shock picture; Surely this can't be right? Spridgets 8
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Reh Spitfire GT6 rear shock to spit mount Triumph 3
KVH Rear Lever Shock Help Triumph 6
M rear lever shock? Triumph 21
D Rear Shock Absorber Links Austin Healey 7
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
bigbadbluetr6 TR6 TR-6 rear tube shock conversion question Triumph 20
M TR2/3/3A TR3 rear shock link question Triumph 4
Z Early BN1 Rear Shock Bolt Dimensions Austin Healey 10
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
K TR4/4A TR4A rear shock conversion kit question Triumph 3
6 Need help with BJ8 rear shock position Austin Healey 2
6 BJ8 Rear Shock Installation Austin Healey 1
JohnnyMead TR2/3/3A Tr3 Rear Shock Link Triumph 4
J Rear Axle Shock Link Help Austin Healey 6
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
mountainman TR2/3/3A TR3 Rear Shock Absorber Fluild Triumph 3
tahoe healey rear shock absorber Austin Healey 9
angelfj1 TR5/TR250 TR250/6 Telescopic rear shock retrofit Triumph 2
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
hondo402000 rear shock rebuild Triumph 11
S Rear Tube Shock Converstions Triumph 17
T TR6 TR6 Rear lever shock rebuild: Triumph 3
Shinsen774 Replacement Tube Shock Rear-Advice MG 1
R Rear shock replacement for the KYB conversion Triumph 8
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
Dave Richards Rear Shock Bolts Austin Healey 6
