Check out this Healey 100 with a Jag V12 convertion [click on the british v8 link]
drambuie
drambuie
Hi Rick.... did you read down to the bottom and then click on the british v8 link? It will bring you to the whole convertion with many great pictures! I had thoughts of cramming a Jag 3.8 six in a Big Healey someday! This way i could drive a Healey and a Jag At the same time and save on garage space! Nice to see a V12 shoe horns in there rather nicely!:victorious:
drambuie
drambuie
Looking at that sprite convertion makes me want to start looking for a 3.8 Jag motor and store it away until im ready for a bn4 convertion.....that sprite has almost all of my ideas i want to incorporate in my future project! I wanted to start with a Jules Frame with rack and pinion to get things started, and maybe a I.R.S rear suspension with 4 wheel disk brakes. I want the outside and interior to look bone stock. However, i would remove the stock bumpers and add lucas driving lamps for a cleaner look. I hope i can follow through with it someday!
M Healey 100-4 Oil Pump Condition Check Austin Healey 3
F Check for matching nrs Austin Healey MK2 Austin Healey 3
K Wow, Check out this Healey Project Austin Healey 16
drambuie Check out the new Healey 5000 Austin Healey 10
C Check out this Custom Turbo Healey, Austin Healey 6
H Check Out the Healey Museum website Austin Healey 2
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
HealeyDave Door Check Friction Adjustment Austin Healey 12
