TR2/3/3A vacuum leaks? How to check
PatGalvin
Hey all
In tuning my British Mistress, I am having some trouble keeping the idle dialed in. My goal is about 900 rpm, but it seems to just move around between 800 and around 1100 rpm, depending on her mood.
I have a semistock engine with a mild road cam (BPNW). Compression is increased from stock by using 87.5mm pistons/sleeves. Dizzy by Jeff at Advanced, with Pertronix. Last checked, compression was around 165 plus or minus 5 psi per cylinder. Engine has less than 1,000 miles on it. Carbs rebuilt by Paltech a few years ago. Valves set at appropriate clearances. Timing per Advanced Distributor's recc's. I've been worried about a vacuum leak on the distributor vacuum advance tube (as possible cause for erratic idle). Is there any way to either check or diagnose a vacuum leak on this line? Or do you guys have other tuning suggestions?
Thanks. She is running very strong, I think. And sounds great. This idle thing is bugging me.
And, of course, when my Spal fan kicks on, the idle drops a couple hundred RPM, due to alternator load. But that's for another thread.....
Pat
TexasKnucklehead
I doubt that tiny vacuum advance line could leak enough to cause erratic idling. Be sure both throttle plates close all the way to the stop freely. It seems that the air moving at idle is enough to keep the throttle discs open a little. A short throttle blip usually gets them to close better. If anything is dragging or out of line, it may prevent normal idle. The biggest issue I had to resolve before my idle speed settled out, was the springs in the mechanical advance of the distributor. A little movement of the advance at low RPM will effect the RPM, so be sure the distributor plate/advance can move freely -it's supposed to get a drop of oil regularly.
If you suspect a vacuum leak, get a foot or two of hose and stick one end in your ear, and move the other end around the carbs and intake, you should be able to hear any significant air leaks. -If your ear is good enough, you can balance the carbs that way.
If you can't get a steady idle, try driving it around a couple thousand miles while not idling long enough to notice.
charleyf
My mechanic friend uses a can of carb cleaner with a fine spray tip( the long plastic tip). With the engine running spray the cleaner around the area you suspect a vacuum leak if the engine speeds up you know that the cleaner is getting into the carb via a vacuum leak. If it does not affect the engine speed --no leak.
Charley
M_Pied_Lourd
Charley
I use a propane torch....unlit of course....:smile: but starter fluid or carb cleaner will work too. Pick your poison!
poolboy
If the appropriate nipple on the carb is used for the Vacuum Advance module on your distributor...there would not be any vacuum at that nipple when the engine was at idle speed.
A jump of 300 rpms sounds like it might be related to a problem with a Vacuum Retard or with a Throttle Bypass Valve.
But having said that I admit I don't know which carbs or which distributor you have, so none of that may apply.
PatGalvin
PatGalvin
59 TR3A
stock dual SUs. no throttle bypass valve on these old boys.
No vacuum retard either.
Pat
bnw
Make sure you are using the proper (not stock) valve clearances for your cam. A quick call to BPNW will verify.
Brinkerhoff
I agree with bnw, first thing is make sure the valve clearances are proper so the cylinders can pump air evenly, then adjust the carbs. Make sure the fast idle , choke , and throttle linkages allow the easy return to idle .
PatGalvin
PatGalvin
Will implement some of your good advice and let you know how it all turns out. Thanks for tips.
Pat
karls59tr
Bronze
I've been told that when you run a non stock cam you you get a "lumpy" idle. I have mild street cam in my 3 and find that 900 rpm is too low for a steady idle.
M Vacuum Leaks Austin Healey 22
sundown TR6 1973 TR6 vacuum leaks Triumph 1
M Vacuum Leaks Spridgets 9
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
bigjones Vacuum advance on a 1500 Spridgets 13
sundown TR6 1973 TR6 vacuum reading Triumph 2
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
