TR6 Vacuum Gauge Timing
SherpaPilot
I have read about an alternate technique in setting engine timing by using a vacuum gauge. I have tried this method on both my TR6 and my 65 Stingray, both resulted in outstanding performance. Having said all that, I am learning this advanced timing afforded by vacuum setting may result in excessive cylinder head temperatures and could cause bearing failure. I have returned my timing on the TR6 back to 4 degrees ATDC but has resulted in lesser response and poor performance. On the other hand, I do not wish to destroy a perfectly good engine either. Does anyone have any experience in this area?
poolboy
Yes, I use a Vacuum Gauge as a visual reference tool instead of damper marks when setting the ignition timing.
Geo Hahn
Timing is timing however you get there -- which method you use doesn't affect performance except to the extent that a particular method results is slightly too advanced timing which may yield the perception of better performance but cause other problems.
I still set it static and adjust it under driving conditions -- but finish by using a timing light to see what total all-in advance looks like. I would think a limitation of timing by vacuum is you do not know where you ended up - unless you then use a timing light to check it. For me - quantifiable and repeatable is best.
TR3driver
Great Pumpkin - R.I.P
The 4 ATDC figure is only for when the vacuum retard is connected and operating. Sounds like maybe yours doesn't work, or is not connected properly
Another possibility is that the timing mark on the damper has shifted, as Ken mentioned.
SherpaPilot
SherpaPilot
Thanks guys. After posting my question, I double checked the manual. The static timing for a 72 TR6 is 12 degrees BTDC. I set that in static mode and will see how it works out.
B TR6 Timing using a vacuum gauge Triumph 13
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
7 General Tech Tuning an engine with a vacuum gauge Triumph 5
M vacuum gauge Triumph 27
I Anyone have a vacuum gauge permanently attached? Triumph 8
jjbunn Adding a vacuum gauge MG 18
F Off Idle Mixture Adjustment with a Vacuum Gauge MG 0
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
T MGB Vacuum advance and Electronic ignition conversion MG 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
M Vacuum Leaks Austin Healey 22
bigjones Vacuum advance on a 1500 Spridgets 13
