Adding a vacuum gauge
jjbunn
I fitted a Voltmeter and Vacuum gauge to the GT's console (it was a tight fit):
The Voltmeter I know how to connect, but the instructions with the Vacuum gauge have left me a little confused. Is this position (circled in yellow) a suitable attachment point for the gauge's pipe?
(It looks almost like it was made for it!)
Thanks!
Nunyas
I think it is. If I'm not mistaken, you want the vacuum to come from the manifold for those gauges.
jjbunn
jjbunn
Thanks guys! I bet that nipple will need some PB Blaster (said the Bishop to the Actress).
jjbunn
jjbunn
[ QUOTE ]
Cool, Julian. /ubbthreads/images/graemlins/smile.gif As I'm sure you know by now, you can diagnose tons of things that are going on inside your engine with a vacuum gauge.
[/ QUOTE ]
Hi Tom ... yes, so I have been reading :smile: As far as I am concerned, the more gauges, the merrier!
jlaird
Now I bet you don't have a smoke gage?
jjbunn
jjbunn
[ QUOTE ]
[/ QUOTE ]
My smoke gauge is simply how clearly I can see the other gauges /ubbthreads/images/graemlins/yesnod.gif
Scott_Hower
[ QUOTE ]
[/ QUOTE ]
I did the same, but mounted just a bit higher. I relocated the hazard indicator to free up some space.
jlaird
I like lots of gages as well but mount them on a seperate alum panel under the Bugeye dash so i can remove them as a set. Oil temp, vacume, Volts, engine hours, etc. Good fun.
jlaird
Oh, a clock, now that's nice.
Platinum
That's my plan for Herself's center console. I am fabricating a "fake" V8 one and plan on a (SMITH'S) clock, voltmeter and either oil temp or vacuum gauge... may opt for all four (wallet permitting). And it gives me room for "modern" audio, foglight switch, fuel pump switch (dual pumps, switchover too) and a few more. She's gonna need a "pre-flight checklist"! /ubbthreads/images/graemlins/grin.gif
jlaird
hehe, pre-start then pre-taxi check list.
Platinum
She's already said she'll be afraid to drive it in traffic... When she gets a load of the "array" I've planned, mebbe ~I'll~ be the "principle driver"!!!
BWUUUHAAHAAHAAAAA!!!!!!!!!!!!!
Bugeye58
So, there's a method to your madness after all!! /ubbthreads/images/graemlins/grin.gif
"Hot and cleared to the active."
Jeff
jlaird
Pre-takeoff checklist complete, flaps at 45. Hot and rolling.
jjbunn
jjbunn
[ QUOTE ]
I see your vacuum and volt gauge and raise you one clock.
[/ QUOTE ]
Oh! A clock! Very nice. But I have no space left :-(
Platinum
[ QUOTE ]
Jeff
[/ QUOTE ]
Roger... Rollin' out.... /ubbthreads/images/graemlins/grin.gif
jvandyke thoughts on adding vacuum ports to carb spacers Spridgets 2
Frameman 1949 Adding an Ammeter Austin Healey 67
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
D Adding hardener to Rusroleum Restoration & Tools 5
G Adding a Brake Booster / Brake Calipers Austin Healey 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
steveg TR6 Adding a PCV valve Triumph 5
M TR6 Adding Some Power Triumph 8
R Adding attachments to your Post FORUM Navigation Questions 1
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
I adding a second fuel pump Austin Healey 16
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
vping T-Series Adding a battery cut off switch. MG 16
Geo Hahn Adding Diode to OD Wiring Triumph 2
M Adding Picture FORUM Navigation Questions 2
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
M Adding Disc Brakes to a BN2 Austin Healey 7
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
theleisure Wiring Question, Adding Reverse Spotlight Spridgets 9
T TR6 Adding lightness to a TR6 Triumph 26
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
K Adding a Radio BN7 Austin Healey 7
AltaKnight Adding JAM Triumph 22
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
Geo Hahn Adding a Headlamp Relay Triumph 19
N Adding an O2 sensor to exhaust? Triumph 25
P Adding pictures? Triumph 15
B Adding lap belts Spridgets 14
OregonTR4A Adding gear oil to the gearbox? Triumph 8
Tronch Adding Fuses Austin Healey 4
19_again adding pix to a post MG 6
vping Adding OD to my '67 MG 23
drooartz Adding a bike Other Cars 40
tony barnhill Still "Adding Lightness" MG 39
S TR4/4A Adding overdrive to tr4 Triumph 7
