TR6 Adding lightness to a TR6
tdskip
Disclaimer - I'm bored and looking for interesting TR6 related things to think about.
So with that said - how would <span style="font-style: italic"><span style="font-weight: bold">you</span></span> go about adding lightness to a TR6?
tom628
I started with 39 lb off by removing the rubber bumpers and brackets (76), and another 6-8 with the Rick Patton fan conversion. I thought about leaving the spare tire at home, but insecurity crept in, as well as not knowing if the change in balance would adversely affect handling. Also, no radio or speakers, with their big magnets.
Lost 20lb off me, but not sure how permanent that will turn out to be.
Tom
BobbyD
Let's see.....I've removed the rubber bumper boobies and front license plate holder which was about 40 lbs. Rick Patton's Fan Eliminator was worth 6 lbs. The Wizard aluminum radiator was good for another 5 lbs. If you go to a Gear Reduction Starter you'll save 11 lbs. Alloy wheels save a lot of weight but I never actually weighed them but I bet at least 5 lbs per wheel. If you have overdrive, converting to a Toyota 5 speed saves about 30 lbs. The Nissan diff actually adds about 13 lbs to the car. Then there's all that Fat Mat sound deadening stuff I've put in the car which probably off sets all the weigh reduction things I've done :wall:
TRTUSH
Skip,
Not sure if you are running with the stock rims, if you are you could switch out to alloy rims and you will find a few pounds there as well.
Cheers,
Tush
Trick6
tdskip:
BobbyD has given you a good list. In addition to his and other suggestions you could change rear brake drums to alum, or better still go to the disc conversion, rear coil over shocks conversion, alum flywheel, the front brake system could be replaced with lighter rotors and calipers, get a SS header to replace the stock cast iron, a single SS big dia. exhaust system, take the convertible top and trash it (fair weather driving only), replace the windshield with that little racing thing, replace the stock motor with a 200 plus HP GM or Ford 4 cylinder alum block/head motor, strip the paint and run primer only, and last get rid of the wife and you don't need the passenger seat. There, done.
Some serious suggestions in there somewhere. It really depends on how light you want to be and how much you want to spend.
martx-5
Just give it a few years and the natural rusting of the body will shed a lot of weight. :laugh: The longer you wait, the lighter the body will get as it starts to look like swiss cheese. :sick:
TR3driver
Great Pumpkin - R.I.P
Hmm, seems no one mentioned the heater (and the water it holds).
To answer your question above, removing rotating mass gives the biggest benefit per pound removed, especially if it's in front of the gearbox. Just an aluminum flywheel makes an amazing difference in 1st & 2nd gear.
TR6oldtimer
DNK said:
How the heck do you "add" lightness.
Helium balloons in all the voids should do it.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Disclaimer - I'm bored and looking for interesting TR6 related things to think about.[/QUOTE]
Why don't you call Dale? I'm sure that he'll give you a few things to think about.
John_Mc
prb51 said:
Remove all of the tools/spares from the boot. I'd lose a good 25 pounds by that alone.
Or in Tinster's case, about 250 lbs!
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]How the heck do you "add" lightness.[/QUOTE]
That's quoting Colin Chapman, I believe, of Lotus fame. Someone correct me if I'm wrong.
2wrench
Sounds like an oxymoron, doesn't it? Get it?? Adding lightness.
Would inflating the tires be adding lightness?
T
TRDejaVu
It seemed to work for Lotus; way back when, right up to the current day.
martx-5
John_Mc said:
...How the heck do you "add" lightness.
That's always been attributed to Colin Chapman. There's another story about Colin that always comes up concerning 'adding lightness'. After he built a car, he would start taking pieces off until the car collapsed on the ground. Then he would put back the last piece he removed. :thumbsup:
Marks6
You could also use:
Aluminium (sorry - aluminum) door skins?
Alloy engine plates front and rear?
Take off every bracket that isn't actually holding something on?
Smaller battery and put it in the rear for better balance?
Remove the bumpers completely - light and it looks cool!
Forged alloy pistons have got to be lighter?
Alloy valve spring caps?
Titanium valve spring keepers?
Teeney weeney fuel tank?
Shave another .001" off the head?
Don't fit gaskets - they don't work anyway?
Use distilled water in the radiator - less heavy metals?
Sorry, as it got harder to think of something useful it got easier to think about something silly.
Beers!
Mark
70 Damson PI
tony barnhill Still "Adding Lightness" MG 39
Frameman 1949 Adding an Ammeter Austin Healey 67
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
D Adding hardener to Rusroleum Restoration & Tools 5
G Adding a Brake Booster / Brake Calipers Austin Healey 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
steveg TR6 Adding a PCV valve Triumph 5
M TR6 Adding Some Power Triumph 8
R Adding attachments to your Post FORUM Navigation Questions 1
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
I adding a second fuel pump Austin Healey 16
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
vping T-Series Adding a battery cut off switch. MG 16
Geo Hahn Adding Diode to OD Wiring Triumph 2
M Adding Picture FORUM Navigation Questions 2
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
M Adding Disc Brakes to a BN2 Austin Healey 7
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
jvandyke thoughts on adding vacuum ports to carb spacers Spridgets 2
theleisure Wiring Question, Adding Reverse Spotlight Spridgets 9
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
K Adding a Radio BN7 Austin Healey 7
AltaKnight Adding JAM Triumph 22
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
Geo Hahn Adding a Headlamp Relay Triumph 19
N Adding an O2 sensor to exhaust? Triumph 25
P Adding pictures? Triumph 15
B Adding lap belts Spridgets 14
OregonTR4A Adding gear oil to the gearbox? Triumph 8
Tronch Adding Fuses Austin Healey 4
19_again adding pix to a post MG 6
vping Adding OD to my '67 MG 23
jjbunn Adding a vacuum gauge MG 18
drooartz Adding a bike Other Cars 40
S TR4/4A Adding overdrive to tr4 Triumph 7
