TR2/3/3A Adding STP to Castrol 20W50 oil?
Sarastro
I'm not a fan of any oil additives. Oil is formulated with great care, and anything it needs is already there. Get a good quality, name-brand oil and it will have everything you need.
There are loads of stories of oil additives damaging engines.
poolboy
The TR6 holds about 5 and 1/2 quarts...of that is 8 oz of STP...I just like the way it makes the Valvoline or Kendall 20w-50 feel a little more slippery.
glemon
I used to use it in my old cars with tired engines to bring oil pressure up. It seems like it would add 5-10 pounds for a while then would break down or whatever and I would be back where I started.
I have decided if you need a rebuild you aren't going to find it in a can.
If your engine is in good shape it should be fine with regular 20w-50.
Either way don't see a good case for using it.
Years ago I used a mixture of STP and motor oil to "upgrade" my lever shocks, which were wearing out. That actually seemed to work pretty well.
Greg Lemon
TR250
PAUL161
STP was used by many back in the 50s and 60s, including me, but today's oils are quite superior in quality, and additives are not needed. If you need to thicken the oil it's possibly rebuilding time. :unsure:
Frameman 1949 Adding an Ammeter Austin Healey 67
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
D Adding hardener to Rusroleum Restoration & Tools 5
G Adding a Brake Booster / Brake Calipers Austin Healey 3
steveg TR6 Adding a PCV valve Triumph 5
M TR6 Adding Some Power Triumph 8
R Adding attachments to your Post FORUM Navigation Questions 1
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
I adding a second fuel pump Austin Healey 16
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
vping T-Series Adding a battery cut off switch. MG 16
Geo Hahn Adding Diode to OD Wiring Triumph 2
M Adding Picture FORUM Navigation Questions 2
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
M Adding Disc Brakes to a BN2 Austin Healey 7
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
jvandyke thoughts on adding vacuum ports to carb spacers Spridgets 2
theleisure Wiring Question, Adding Reverse Spotlight Spridgets 9
T TR6 Adding lightness to a TR6 Triumph 26
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
K Adding a Radio BN7 Austin Healey 7
AltaKnight Adding JAM Triumph 22
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
Geo Hahn Adding a Headlamp Relay Triumph 19
N Adding an O2 sensor to exhaust? Triumph 25
P Adding pictures? Triumph 15
B Adding lap belts Spridgets 14
OregonTR4A Adding gear oil to the gearbox? Triumph 8
Tronch Adding Fuses Austin Healey 4
19_again adding pix to a post MG 6
vping Adding OD to my '67 MG 23
jjbunn Adding a vacuum gauge MG 18
drooartz Adding a bike Other Cars 40
tony barnhill Still "Adding Lightness" MG 39
S TR4/4A Adding overdrive to tr4 Triumph 7
