Adding Disc Brakes to a BN2
mwagon
Welch & Cape sell Disc Brake kits, but on the front can the later BT7/BN7 style Caliper Adapter be bolted to the original BN2 axle for mounting the Brake Caliper? Would the existing Hub work to or would it need to be replaced to accomodate the Brake Rotor?
It looks like the Welch Kit uses a Dunlap Caliper, as on XK150's, with their own Adapter design
dougie
If your looking to upgrade to disc. brakes on your BN2, you might consider replacing (upgrading) to the stronger BJ8 front spindles/stub axle. The brake calipers bolt directly to them and if your needing disc. brakes for more "spirited driving" replacing the always suspect 100 spindles will give you great piece of mind. I know this didn't answer your question, just a thought before you start tearing things down.
Dougie
Randy_Gay
According to Moss, the spindle is the same for later BN2 (from C.E.231203 LHD & 231148 RHD) through early BJ7. If so, the disks could be mounted. The master cylinder would have to be changed out as well.
glemon
Why do you need to change out the brake master cylinder with the swap?
I had a BN1 with disc conversion, original master.
musme
I am also thinking about doing the disk brake conversion.
I am so confused....
Should I only do it in the front brakes ?
I was considering Welch in the UK
Which is the best option ?
"AH100M" & "glemon" members: How were your conversions done ?
Does anyone besides Welch offers the complete conversion kit ?
It seems Moss does not offer the spindles that Randy Gay mention as been the same for the BJ7
Happy motoring
Jose V Vargas Bogota, Colombia South America
AH100M
I used the kit from Welch. Some shortcomings - no explicit instructions but not tot tough to figure out how to install. Plus, when I had questions they were answered promptly via email. Also, no shims for adjusting the end play were included. Welch said they would include an assortment in future shipments (this was in 2005). They sent me a set of about 20 shims in the sizes I asked for at no charge.
I would recommend the kit from Welch with these slight reservations. If you want me to send you the email thread about these issues let me know.
AH100M
Oh, I saw no reason to do the rears. Most of the braking is accomplished by the fronts.
As an aside as to why I did the conversion. My car spontaneously started pulling violently to the right upon braking. I spent tens of hours troubleshooting (I know what I'm doing) and I got down to bad (new) brake shoe linings one one side. Having no way to prevent this from happening again, with no notice, I decided to convert.
Frameman 1949 Adding an Ammeter Austin Healey 67
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
D Adding hardener to Rusroleum Restoration & Tools 5
G Adding a Brake Booster / Brake Calipers Austin Healey 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
steveg TR6 Adding a PCV valve Triumph 5
M TR6 Adding Some Power Triumph 8
R Adding attachments to your Post FORUM Navigation Questions 1
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
I adding a second fuel pump Austin Healey 16
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
vping T-Series Adding a battery cut off switch. MG 16
Geo Hahn Adding Diode to OD Wiring Triumph 2
M Adding Picture FORUM Navigation Questions 2
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
jvandyke thoughts on adding vacuum ports to carb spacers Spridgets 2
theleisure Wiring Question, Adding Reverse Spotlight Spridgets 9
T TR6 Adding lightness to a TR6 Triumph 26
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
K Adding a Radio BN7 Austin Healey 7
AltaKnight Adding JAM Triumph 22
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
Geo Hahn Adding a Headlamp Relay Triumph 19
N Adding an O2 sensor to exhaust? Triumph 25
P Adding pictures? Triumph 15
B Adding lap belts Spridgets 14
OregonTR4A Adding gear oil to the gearbox? Triumph 8
Tronch Adding Fuses Austin Healey 4
19_again adding pix to a post MG 6
vping Adding OD to my '67 MG 23
jjbunn Adding a vacuum gauge MG 18
drooartz Adding a bike Other Cars 40
tony barnhill Still "Adding Lightness" MG 39
S TR4/4A Adding overdrive to tr4 Triumph 7
