TR6 Vacuum Gauge Hookup
Gliderman8
I want to try the vacuum gauge method of timing my car.... '73 TR6.
Where is the best place to hookup the vacuum gauge?
The charcoal canister is not used and is disconnected.
Any other tips on timing with a vacuum gauge are also appreciated. Thanks!
poolboy
If you still have the banjo fitting on your intake manifold and if it's the 73 version, there should be 2 nipples...A big one for the Servo and a smaller one...originally for the ARV.....the smaller one is the one to use to connect the Vacuum gauge hose.
Gliderman8
Gliderman8
Thanks Ken. Going to look.
Gliderman8
Gliderman8
There is only one banjo fitting on the manifold. Is this the one?
Also the small rubber cap on the banjo fitting is dried out; is there a source for them?
Gliderman8
Gliderman8
Thanks for the links. Good info.
poolboy
That's THE one and only banjo fitting as it should be for a 73 (and 74) with 2 nipples... and that cap on that small nipple must be TIGHT when you replace it or it will suck excessive air into the engine combustion chambers...
You can find emission plugs that fit at auto parts stores, usually on the rack for "Dorman's " universal type stuff
Gliderman8
Gliderman8
Thanks again.
Gliderman8
Gliderman8
Got the vacuum gauge on and it was reading about 16-17 inches Hg. Advanced the distributor and raised it to 20+ but I backed it down to about 19. Should I take it higher?
poolboy
I wouldn't, Elliot, until you spend some time driving around at 18 to 19.
You don't want to over advance based solely on the higher manifold vacuum.
Gliderman8
Gliderman8
Thanks for the advice. I ordered the emission rubber plug... it will be here tomorrow. I'l put it on and then drive it for a while so see how it goes.
B TR6 Timing using a vacuum gauge Triumph 13
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
7 General Tech Tuning an engine with a vacuum gauge Triumph 5
M vacuum gauge Triumph 27
I Anyone have a vacuum gauge permanently attached? Triumph 8
jjbunn Adding a vacuum gauge MG 18
F Off Idle Mixture Adjustment with a Vacuum Gauge MG 0
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
T MGB Vacuum advance and Electronic ignition conversion MG 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
M Vacuum Leaks Austin Healey 22
bigjones Vacuum advance on a 1500 Spridgets 13
