TR4/4A TR4 AUC878 vacuum connections
Twit
Member
I'm reassembling an early TR4 CT2292. It was someone else's project and came totally disassembled except body, the block and the tranny(which is now out and off to add on an overdrive).
It came with a new AUC878 dual carb setup. I'm now trying to figure out the vacuum connection for this and its surprisingly hard to find any info. Shop manual is no help. Moss motors parts shots don't show enough. I think its a screw in connection to just the bottom of the front carb but I am not sure.
thanks Dave
TRopic6
Hi Dave, I have an early TR4, but not as early as yours. The TR2/3 had a brass fitting on the bottom of the front carb that a steel line with a compression nut screwed to. The TR4 used a small copper line with a fitting that screwed directly into the bottom of the carb. Your car should use a direct screw-in connection to the carb but its possible there was overlap in the early TR4s. I have some TR3 carbs and fittings I can photograph & measure tomorrow. My TR4 is in storage but I do have a TR4 SU carb set to check.
I encountered the same confusion 40 years ago when I got a complete vac line from a junkyard TR3A and tried to fit it to my TR4 - the brass union from the TR3 carb was too big for the threaded opening in the TR4 carb. I think the Moss vacuum line 23 on their Ignition/Distributor page will work though.
Jeff
James A Martin
Jeff,
Same boat here, with my TR3B. I just had my carbs looked at and everything looks OK except the vacuum line connection. I have a new rebuilt distributor with a vacuum advance on the way. The distributor that came with the car had none. The fitting on the bottom of my H6 carbs was plugged. The fitting is 1/4" with a 1/8" hole, no threads in the hole in the fitting. I'm looking for a way to connect the carb and distributor. I'll measure the threads today when i get to my shop. I'm hoping I don't have to alter the carb to fit a larger fitting.
Fitting size and dimensions in the catalogs would be useful. I guess they don't put them in their description because people would purchase from a different vendor if they had that info.
Following this...
Jim
Twit
Twit
Member
I got off my butt and pulled the carbs off again. There is a threaded entry on the bottom of the front carb.
So now that I understand I just have the one connection I'm looking at the options offered by MOSS. My distributor has a slip on connection so none of the Moss configurations fit the setup. That is probably because the carbs and dist are both new so no guarantee they are both early TR4 versions.
I think what I need to do is get the option with the male and female ends and just cut off the female end. For now I'm plugging them as the motor has been rebuilt but never started and I can live without the advance for now. Getting parts into Canada with the COVID lockdown is pricy so I'm looking to do an order of all the little bits I find missing and I'm going to need all the overdrive stuff at the very least and some cables. I haven't even started on the dash as I want to put the tranny back in first so I don't damage anything.
thanks for the help Dave
TRopic6
Sounds good. You may be able to fit a short rubber connector (like the TR6 uses) to connect the Moss #23 line to the vac unit, then thread the female screw-on connector onto the rubber coupling.
Jeff
Twit
Twit
Member
So the Moss pipe worked fine. The ends were press fit so didn't even need to cut the one off. But I did have to do a reduction from the distributor to the pipe. To do that I just nipped the ends off the rubber end covers and married them as they were just the right size.
2997L
thanks Dave
Hey Dave... I have an early TR4 as well... CT2997 that I did a concourse
body off resto about 20 years ago... I have lots of pictures and can take more if you ever need any help...
PS My name is Dave too, and I live in Ontario...
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
Twit TR4/4A restoring TR4 sun visors Triumph 0
