Vacuum Advance Pipe
barnman
Good afternoon gents. Anyone have any detailed pics of the way the copper vacuum advance pipe runs from carb to distributor?
Thanks in anticipation, as always.
gonzo
Re: Vacuum advance pipe
Routing is different depending on model. Please specify. On a BJ-7 there's a vacuum hose that attaches copper pipe to rear carb, then it routes around backside of cylinder head above heater tap then on to distributor where is screws into the vac advance canister by olive and nut.
B
barnman
Thanks for that, car is a late BJ8 the vacuum pipe fits on 2 rubber connectors, one at each end.
WHT Vacuum Advance Pipe Austin Healey 7
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
JPSmit Today's question - vacuum advance Spridgets 2
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
D TR2/3/3A Vacuum advance tube Triumph 6
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
T MGB Vacuum advance and Electronic ignition conversion MG 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
AUSMHLY Vacuum advance knob Austin Healey 21
DanLewis Vacuum advance question Spridgets 5
apbos H1 SU vacuum advance frustration. Spridgets 9
DMShuman TR5/TR250 TR-250 Vacuum advance module.... Triumph 5
C TR4/4A TR4A with TR3 distributor and Vacuum Advance Triumph 4
Tinkerman TR2/3/3A 1960 TR 3A vacuum advance line installation Triumph 7
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
S TR2/3/3A vacuum advance tr3 Triumph 2
S banjo type fuel lines--vacuum advance Triumph 0
D '78 Midget Vacuum Advance Unit Spridgets 7
TulsaFred Bugeye Vacuum Advance Spridgets 5
M a discussion on Installing new vacuum advance unit Triumph 20
DrEntropy Vacuum advance or vacuum leak?! MG 2
SkinnedKnuckles Ported vs Manifold Vacuum Advance Triumph 5
G Anyone have a vacuum advance for a 45DM4? MG 4
Tinkerman TR2/3/3A TR3A Vacuum Advance Suction Tube Tool Needed Triumph 8
Tinkerman I Having A bad vacuum advance line day Triumph 5
Tinkerman TR2/3/3A TR3A Vacuum Advance Line Triumph 2
Tinkerman TR2/3/3A TR3A Vacuum Advance Hook Up Triumph 13
A Mk 1 Frogeye Vacuum Advance Spridgets 6
A Mk1 'Frogeye' Sprite Vacuum advance connections Austin Healey 2
jvandyke vacuum advance question Spridgets 5
Stinger TR4/4A TR4A Vacuum Advance Question Triumph 16
G New Spark Advance Vacuum Triumph 1
L Vacuum Advance question Spridgets 9
C vacuum advance hose Triumph 12
hondo402000 vacuum advance for triple webers Triumph 2
spit71 Spitfire My Spitfire doesn't have a vacuum advance Triumph 14
Tinkerman Vacuum Advance Rebuild? Triumph 2
zimmy vacuum advance Spridgets 17
