Vacuum advance question
DanLewis
I think I may need to reconfigure my vacuum advance, but first I wanted to see if anyone here could offer some sage advice.
I have a Weber 40DCOE on my BE. The Weber didn't have a vacuum port but the manifold did, so I connected the vacuum advance unit on the distributor to the vacuum port on the manifold. However, I have a suspicion that the vacuum advance unit was designed to work with a carburetor vacuum port and not a manifold port. I say this because of the way the car behaves. When I step on the gas, the power drops unless I back off and slowly let the rpms come up. I.e., before opening the throttle, there's a lot of manifold vacuum, and I get lots of vacuum advance. But when I open the throttle, the manifold vacuum drops significantly and the timing is no longer advanced until the rpms come up.
IIRC, the vacuum port on a carb is usually above the throttle plate. If so, then I think the vacuum would behave almost opposite to what I just described: Before stepping on the gas, there would be very little vacuum above the throttle plate. As the throttle is opened, however, more air is drawn through the carburetor causing the vacuum presented to the distributor (and thus the amount of advance) to increase.
I know someone will tell me to just disconnect the vacuum advance, but my understanding is that the additional advance from the vacuum advance unit actually is supposed to improve low-end throttle response.
Does anyone here know enough about these things to tell me if my reasoning is on track? If I need to connect the vacuum advance unit to a vacuum port on the carb, I think I saw in an exploded parts diagram that the 40DCOE actually does have a provision for adding a vacuum line. I think it's normally blocked off by a screw, but maybe it could be replaced by a fitting that could be connected to the vacuum advance unit. (See part #48 here.)
So - what do you guys think?
Dan
nomad
I'm surely not an expert but I've run cars on SU's both ways. Carburetor ported advance just eliminates vacuum advance at idle which gives you a smoother idle and seem's to make the engine less prone to overheating at a stop light. Above that I don't believe it make's much difference since manifold vacuum drops as soon as the throttle is opened. Perhaps there is still a differential on either side of the throttle plate that the distributor is designed for that could make a difference. Wonder if Vizard has anything to say about that??
IMHO I would think you need to dump more fuel in from the accelerator pump or equivalent on a DCOE. There is supposedly a Guru on DCOE's and I'm not him!:highly_amused:
Kurt.
DanLewis
DanLewis
Hi Kurt,
Well, maybe that explains why my car overheats so much at idle - even with a special aluminum radiator! :grumpy:
I just found a post on another website that said it's a common mistake when installing a Weber to connect the vacuum line to the manifold, and that it causes a big stumble when you give it gas! Well, I guess I'm guilty!
I have a mechanical-advance electronic distributor (no vacuum advance) that I removed in favor of the one with vacuum advance, thinking that it would give better low-throttle response, but I guess my big mistake was to connect it to manifold vacuum. Maybe I'll just give up and put the mechanical advance distributor back on. :peaceful:
Dan
bug_sixty
Vac on DCOE's is mech. only.. no vac of any kind on manifold... Just never works out as much as I know...The hesitation is common on them I might add...
bugi
Member
You might want to contact Jeff at advanceddistributors.com and have him reprogram the advance curve on your distributor. His website has a work sheet for the specs of your engine. I have a 45DOCE with a Kent 276 cam and headers. He reset my curve and now my static timing is 16 degrees BTDC. This has pretty much solved the hesitation problem. Webers don't like to transition very much. I have a Crane electronic ignition system. Webers use mechnical advance.
Healey on.
Ray
DanLewis
DanLewis
Hi Ray,
You might want to contact Jeff at advanceddistributors.com and have him reprogram the advance curve on your distributor. His website has a work sheet for the specs of your engine. I have a 45DOCE with a Kent 276 cam and headers. He reset my curve and now my static timing is 16 degrees BTDC. This has pretty much solved the hesitation problem. Webers don't like to transition very much. I have a Crane electronic ignition system. Webers use mechanical advance.
Good advice, and I have heard great things about Jeff's work, but I'm not ready to take the plunge just yet. The non-vacuum-advance distributor I have is new and is supposed to be designed for the 1275. I put it on the car last night and it seemed to make things a lot better, but I was only able to do a rough set on the timing. I'd like to see what setting the timing correctly does before trying something else. I'm waiting on a new throttle cable to arrive before I go any further because the one on the car is binding, preventing the throttle from returning all the way to idle.
My distributor is electronic, made by Accuspark in England (see it here). The mechanical advance kicks in with around 4 degrees of advance at 750 rpm and flattens out with 16 degrees at 4000 rpm. Of course those numbers are added to any initial (static) advance setting. However, you can't set static timing - you have to set timing with the engine running. I'd really like to find out from someone how much total advance I should have around 4000 rpm - then I could set the timing correctly.
My other option that I'm curious about is going back to the vacuum advance distributor, and finding a way to get ported vacuum from the carburetor. The 40DCOE 151 doesn't have a vacuum port but it appears to have a place for one that is currently blocked by a screw-in plug. There's one on each side of the carb, and I believe it was intended for balancing the vacuum between the two sides (or four if there were two carbs). Anyway, I saw in a post on another website that someone was considering the same thing (see here).
So many things to try, so little time. :fat:
Dan
JPSmit Today's question - vacuum advance Spridgets 2
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
jvandyke vacuum advance question Spridgets 5
Stinger TR4/4A TR4A Vacuum Advance Question Triumph 16
L Vacuum Advance question Spridgets 9
1 Novice question about vacuum advance line. Austin Healey 26
B Vacuum Advance Question Austin Healey 7
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
WHT Vacuum Advance Pipe Austin Healey 7
B Vacuum Advance Pipe Austin Healey 2
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
D TR2/3/3A Vacuum advance tube Triumph 6
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
T MGB Vacuum advance and Electronic ignition conversion MG 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
AUSMHLY Vacuum advance knob Austin Healey 21
apbos H1 SU vacuum advance frustration. Spridgets 9
DMShuman TR5/TR250 TR-250 Vacuum advance module.... Triumph 5
C TR4/4A TR4A with TR3 distributor and Vacuum Advance Triumph 4
Tinkerman TR2/3/3A 1960 TR 3A vacuum advance line installation Triumph 7
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
S TR2/3/3A vacuum advance tr3 Triumph 2
S banjo type fuel lines--vacuum advance Triumph 0
D '78 Midget Vacuum Advance Unit Spridgets 7
TulsaFred Bugeye Vacuum Advance Spridgets 5
M a discussion on Installing new vacuum advance unit Triumph 20
DrEntropy Vacuum advance or vacuum leak?! MG 2
SkinnedKnuckles Ported vs Manifold Vacuum Advance Triumph 5
G Anyone have a vacuum advance for a 45DM4? MG 4
Tinkerman TR2/3/3A TR3A Vacuum Advance Suction Tube Tool Needed Triumph 8
Tinkerman I Having A bad vacuum advance line day Triumph 5
Tinkerman TR2/3/3A TR3A Vacuum Advance Line Triumph 2
Tinkerman TR2/3/3A TR3A Vacuum Advance Hook Up Triumph 13
A Mk 1 Frogeye Vacuum Advance Spridgets 6
A Mk1 'Frogeye' Sprite Vacuum advance connections Austin Healey 2
G New Spark Advance Vacuum Triumph 1
C vacuum advance hose Triumph 12
hondo402000 vacuum advance for triple webers Triumph 2
spit71 Spitfire My Spitfire doesn't have a vacuum advance Triumph 14
