TR4/4A Vacuum connection on SU-H6 carbs
E
eyesie
I am trying to install the vacuum connection on the front carb. The part I have from an old carb, see photo, does not seem to want to screw in. The the ad appears to be too big. Can anyone tell me what is the thread in the manifold? Were ther different sizes? I don't want to have to pull the carbs off to get a better look at this threaded hole, but if I have to!! Moss show P/N 80, and call it a union, which it isn't, but their price is $23 for what appears to be a standard compression fitting.
Any thoughts would be appreciated.
Dash
I have a spare set of SU 878's's that I just measured with a digital caliper and get a reading of 3/8 and seems to be fine thread. The part# you refferenced in the Moss catalogue specifically states for 768's but I'm guessing they would be the same since they don't list one specifically for 878..but maybe not..
TR3driver
Great Pumpkin - R.I.P
IIRC there were at least two, maybe three different arrangements used by SU (if not necessarily Triumph), with different threads in the carb body. As confirmation, I picked two bodies at random from the parts bin, and confirmed that they have different threads. The body with AUC6040X molded into it still had it's fitting, which appears to be 5/16" BSF (22 tpi and has 5/16 BSF flats on it). The body with AUC6040AC molded into it had a visibly smaller hole and the adapter from the other carb will not screw into it. I suspect the 6040X is from a 786 carb and the 6040AC is from 878; but don't know for sure. If someone else knows how to tell the bare bodies apart, I'd like to hear about it! Oddly enough, they both appear to have 6058 hand-inscribed below the casting number.
Also FWIW, the TR3 SPC and TR4 SPC list different part numbers for that adapter/union.
There is also the possibility that someone has mistakenly rebuilt a rear carb as a front carb. The rear carbs have a blank (unthreaded) hole.
Snowkilts
I've just been looking at this exact issue. Mine was attached without a fitting. At first I thought this was a mistake, but on looking closer, it appears that the hole in the carb is machined to accept a compression nut directly. I plan to hook it up and see if it's actually holding vacuum.
Snowkilts
Just verified that the machined-in compression fitting in my H6 carb does in fact hold vacuum. There is no separate union or fitting (Moss #80 in OPs picture). Unfortunately, I also confirmed that my vacuum advance unit does not hold vacuum, so I guess I'll be replacing that (again).
D TR2/3/3A Vacuum connection at Carb Triumph 23
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
M Vacuum Leaks Austin Healey 22
bigjones Vacuum advance on a 1500 Spridgets 13
sundown TR6 1973 TR6 vacuum reading Triumph 2
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
B TR6 Vacuum retard late TR6 Triumph 4
