Source for spray cans of touch-up paint?
rotoflex
Can anyone recommend a good source to buy spray cans of touch-up paint?
Autocolorlibrary.com just gave me a major headache in that the 1st stage of their paint selection process is getting a paint code from a vintage card with paint chips, & of course the paint code for Damson is obliterated from their card.
Also, what do folks recommend for the silver color that was used on Spitfire/GT6 wheels & TR6/GT6 valve covers?
martx-5
Tower Paint ...My son got some spray cans from them for his V-Dub when he was adding some body tupperware. The paint they mixed up for him in the spray cans were a perfect match to the car.
tdskip
For what it is worth I used Paintscratch recently for two touch up paints premixed and delivered in spray cans.
The BRG was a touch off, but to be fair it could be that paint my DPO used wasn't the correct tone.
The other color I ordered was spot on.
Their online site isn't the best, but I received the order quickly.
jerrybny
I used a can of white from paintscratch. Hard to tell the difference from where I sprayed and where the original meets. I also used their touchup pen for some nicks and am very happy with their product.
habaneronut
I just recently got some red from O'Reilys Auto Parts in a can. They have a camera thing they put on the hood of your car in several places, and then mix the color from whatever that gives them. They did me a virtually perfect match. Then, they have a little spray can deal for about $5 bucks that you can put the paint in to do spraying of small areas. I haven't tried it yet, but I hear they work great. I've been using the Q-tip method that's out on the VTR website. Lots of work, but it's working for me.
1/2 pint of the paint was $12.
Fred
Harry_Ward
I am having problems with it too. The sites images are not loading correctly on the paint car identifier plate gif. It's not only the Triumph car it's all.
Arrow
Many auto paint suppliers can mix the paint and put it in cans. Ask a body shop where they get their paint and call them. In Atlanta ther are several stores called "Auto Color" and not all of them can put it in the spray can for you but their largest store does and ships it to the one you want to pick it up at. I had them mix some for my Pierce Arrow Jack and it worked perfectly.
G
Another option is to have your automotive paint supplier (I have used PPG) to computer-match your existing paint job. They will usually four different shots of your paint from four different flat surfaces and their computer reads the colors, giving a very, very close color match. This might come in handy if you have a custom color or a faded color. No two mixes of paint ever come out the same, even when using the same formula. Then use one of those disposable paint sprayers as mentioned above. Since my paint is a custom color and is basecoat/clearcoat at that, the computer generated color worked perfectly for me. I had the paint mixed in a 1/2 pint size (they wrote the formula on the can for me) in acrylic enamel which applies over rock chips easily and dries with its own shine. Being dissimilar paints doesn't matter, and filling a rock chip takes several micro-layers to fill the hole but the result is quite acceptable.
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
Patrick67BJ8 "Cover" for Top. Source wanted Austin Healey 6
