slight clicking/tapping noise after a head rebuild
SANdMAN_the
Member
i recently put back the head on my 69 midget and fired her up...and i have a strange tapping/clicking noise which appears to be coming from under the valve cover. i did set the clearence to .012 when the engine was cold.
i spoke to my friend and he said that with a "big" clearence like .012, i can expect to hear some clicking.
is this just another quirk on owning a midget?
thanks,
john
jcatnite
Don't know what the valve clearance spec for your engine is but that can very well be the source of the noise. I have a 76 with a 1500 in it and the spec is .010 cold. I set them to that spec a little while ago and the valves are a great deal noisier now. The PO had them set to anywhere from .006 to .014 cold. It has to do with the solid lifters that are in these engines. I would let them "run in" a bit and then check them to see if the clearances have shifted at all.
JC
aeronca65t
Always safer to have slightly loose (and noisey) valves. If they are too tight, they may burn. If they are a bit loose (by a few thousands of an inch) no harm will be done. 0.012" is correct for the 1275 cc enigne.
When you adjust valves in all Brit inline pushrod fours, use the "Adds to Nine" method.
When valve #1 is fully down, adjust #8.
When valve #2 is down, adjust #7...and so forth.
To get valve in position, it's easier to put the car in fourth gear with handbrake off and push it until the valve is where you want it.
dklawson
When you put the head back together, did you check the condition of the rocker arm pads? Regardless of whether you have the forged steel, stamped steel, or sintered arms, if the pads are worn (flat spots or ridges) they can add to the ever present ticking of the valve train.
S
SANdMAN_the
Member
thanks for the advice everyone! i'll double check the valve clearences tonight, but it's sounding more like it's just a normal sound for this car :smile:
john
K TR2/3/3A Slight surging at Idle? Triumph 11
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
S TR2/3/3A Slight clunk in the rear assembly somewhere. Triumph 3
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
Martinld123 A slight hesitation stumble at speed Austin Healey 13
busybrit MGB Slight starter motor noise MG 5
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
JPSmit Slight rant Other British Cars 9
V 1275 slight miss, what's the cause??? Spridgets 20
Anthony_S TR2/3/3A TR3a slight shake at 60-65 mph Triumph 8
M Slight bind in front brakes Spridgets 7
bigjones Slight timing problem Spridgets 3
longbridgehealey very slight miss Austin Healey 3
T GT6 slight vibration in GT6, with power Triumph 4
bigjones HS4 - 1500 - slight problem Spridgets 24
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
bigjones Slight wheel alignment problem Triumph 9
JPSmit slight rant - solenoid Spridgets 3
J Spitfire Slight intermitant 78 Spitfire Triumph 14
kodanja Slight changes Triumph 16
Woodie hs2's slight hesitation under load Spridgets 40
P Slight engine hesitation Spridgets 7
P Slight loss of brake assist until pumped once Triumph 4
Sherlock Suggestion for "slight" name change Rover / Land Rover 1
Basil Slight problem with rear hubs [EType] Jaguar 7
Carlbanan56 MGB Rear wheelbearing clicking MG 8
S Spitfire Differential clicking Triumph 6
M TR6 Clicking sound when accelerating Triumph 11
Upland Clicking from rear Spridgets 14
KVH TR4/4A TR4--Clicking Like Tappets Triumph 16
S TR6 TR6 Starter/solenoid Clicking Triumph 1
R Transmission Clicking Triumph 9
regularman heard a clicking sound and found the cause Spridgets 6
G FUEL PUMP WON'T STOP CLICKING Austin Healey 12
M T-Series Clutch clicking/tinging when engaged MG 5
doughairfield Clicking sounds Triumph 43
R Clicking noise when applying brakes Austin Healey 4
Dadandson My U Joints are clicking away Spridgets 14
C Clicking in Right Rear of 1500 Triumph 5
BoneIdle Clicking in reverse MG 1
W valves clicking...i think - need advice Triumph 11
78MGB Fuel Pump Will NOT Stop Clicking!!!! MG 20
RAC68 Heavy Tapping low in the Engine Austin Healey 58
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
catfood Self tapping screws an rust prevention Austin Healey 10
R Top end engine tapping Austin Healey 5
G TR2/3/3A TR3 Tapping Plate ???? Triumph 3
2wrench Tapping in the freeze plugs pics Triumph 1
