slight rant - solenoid
JPSmit
OK, not the solenoid exactly but I put on a new one tonight and would like to know, why would they put 12mm nuts on an LBC solenoid?
sigh :wall:
thank goodness for metric wrenches
14dna
JP;
You are in Canada now.
If anyone can explain why we have the metric system, then your problem will become crystal clear.
I'm sorry if this is a little political!
Dave :wall:
JPSmit
JPSmit
oh i don't mind the metric system even if I still think in imperial. But, this was a Moss part from the good old USofA
JPSmit Slight rant Other British Cars 9
K TR2/3/3A Slight surging at Idle? Triumph 11
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
S TR2/3/3A Slight clunk in the rear assembly somewhere. Triumph 3
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
Martinld123 A slight hesitation stumble at speed Austin Healey 13
busybrit MGB Slight starter motor noise MG 5
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
V 1275 slight miss, what's the cause??? Spridgets 20
Anthony_S TR2/3/3A TR3a slight shake at 60-65 mph Triumph 8
M Slight bind in front brakes Spridgets 7
bigjones Slight timing problem Spridgets 3
longbridgehealey very slight miss Austin Healey 3
T GT6 slight vibration in GT6, with power Triumph 4
bigjones HS4 - 1500 - slight problem Spridgets 24
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
bigjones Slight wheel alignment problem Triumph 9
J Spitfire Slight intermitant 78 Spitfire Triumph 14
kodanja Slight changes Triumph 16
Woodie hs2's slight hesitation under load Spridgets 40
P Slight engine hesitation Spridgets 7
P Slight loss of brake assist until pumped once Triumph 4
Sherlock Suggestion for "slight" name change Rover / Land Rover 1
S slight clicking/tapping noise after a head rebuild Spridgets 4
Basil Slight problem with rear hubs [EType] Jaguar 7
G Supplier rant from down under Austin Healey 12
69sprite eBay listings rant Spridgets 16
glemon Arrgh! Carb Conversion Rant Triumph 4
Andrew Mace Parts rant! Part II Triumph 8
Andrew Mace Parts rant! Triumph 10
Marvin Gruber Fuel Rant Austin Healey 0
glemon Rubber Seals Rant Triumph 4
TR6oldtimer Brake line rant, sort of... Triumph 11
Patton Whiny Rant - [Don't waste your time to read] Austin Healey 15
Bruce_B Help Needed with '59 BE in NJ - Rant and Questions Spridgets 5
philman auto parts store clerk rant Restoration & Tools 30
1965_MGB DPO Rant MG 5
RickB OT: Ebay rant - please forgive the following... Spridgets 29
Hap Waldrop Caution!! Rant about to begin!!!!!! Spridgets 37
R6MGS *modern* cars.....rant Other Cars 21
Bret Oh Shazbot! Got a Radiator leak on my Shark <RANT> Other Cars 3
wkilleffer T-Series Rant about turn signal and headlight switch MG 37
A Plain White Box Parts Rant...This Week MG 2
DrEntropy Another rant over "the usual suspects!" MG 22
R6MGS Pickup Shopping [minor rant ahead] Other Cars 12
saabmp3 Rant: No brakes Spridgets 10
IanF Mislabeled part rant... and weekend ramble... Triumph 0
TR4nut Vendor rant Triumph 21
