glemon
Frustration: Finding out things that seem to be going really well aren't
LBC Frustration: Thinking this went well and you are about done...then
I am fitting Stromberg 175 CD Carbs to my TR250 to replace the emmission control 175 CD-2s currently on the car. They bolted right up, the connection rod for the throttle shafts fitted with the throttle connection even fit perfectly to the new shafts I bolted it all in and snugged it down and....went to move the pushrod throttle mechanism by hand and its totally stuck.
Moves fine in the other direction, the throttle plates on the 175 CDs rotate in the opposite direction of the CD2s, I think I could flip the plates and springs around, maybe, but I don't think they are meant to be that way.
Otherwise will have to futz around with the throttle linkage, I liked it when I thought I could use the stock mechanism and not have to cobble something together, then I had the problem and it was time clean under the fingernails to go out with the wife for new years. Was excited about firing her up on the new carbs before I quit, was not to be.
Will try to figure something out tommorrow (which is already today)
