Bruce_B
After trying everything I know, I stll can't get my rebuill 1275 engine started - getting really discouraged. It's summertime and I should be out there cruising.
Been working with the HIF4 Carb. But even if there's a problem with that, it still should start with starter fluid put into the carb.
I've checked the position of the dist. with the 1st cylinder TDC and seems OK.
(1) Question - what's that rule about backfire from the rear is timing, backfire from the Carb is Gas-- or is it the other way around. I do get an occasional DUb-DUB, but that's it.
Have new high torque starter installed. Another problem I'll start the car and turns over OK...but then the starter will make a high pitched whine as if flywheel is not engaged. I'll put car into a gear, push back and forther, put out of car. Then starter seems to work.
(2) What could be causing that? Starter seems installed fine.
(3) any other ideas....things to check out? Spark is good.
Any help is much appreciated. If anyone is in the area, near Flemington, NJ -- visits also appreciated-- of course with full beer and pizza provided.
thanks...
To all of those going to the Lake---which I was joining you.
Safe Driving.
thanks...
Safe Driving.
