Help Needed. Alternator Question
M
Mike
I feel like an idiot. I was installing a new belt and had loosen my alternator to install the belt and broke a mounting bracket tab. What is the fix? Do I need to buy a new alternator? Moss Motors shows a alternator conversion kit on their web site. Would that be the right replacement? I can not identify the model number of my existing alternator due to printed number on the I.D. sticker being faded. My engine is a 1257. My engine tag is 12V/671Z/L 4584. From asking on the forum a couple of years ago, one of the replies indicated my engine was probably manufactured in 1972, not sure.
Thanks,
Mike
JPSmit
sorry to hear - hopefully BillM will be along in a minute to say that he still has 47 alternators for sale cheap and he can fit one (or even the case) in a $10 US Post box. You could probably get it welded but I would be nervous.
nomad
Looks suspiciously like a GM alternator to me. If so it should say Delco somewhere. I'd take it to my local friendly auto parts store and see if they know what it is. Maybe they would know a mechanic with one laying behind the shop that you could steal a case off of!
Kurt.
Billm
I think that I have one of those (GM?) but that one has been ground to fit and looks like that is why it broke.
I have a bunch of Datsun ones really cheap but you would have to wire it up.
BillM
MichiganTed
You have a GM 10-SI style alternator. One of the most common alternators used by GM for years and years and years. Easy to change the drive end housing yourself or you can take it to a rebuild shop and have them swap out a new end plate. Depending on time/mileage on the alternator, I'd suggest replacing the drive end bearing.
You'll need an impact gun to remove the pulley - just hold the pulley in one hand while you spin the nut off using the impact gun. And you'll need to note the "clock" position when you remove the 4 through bolts (the two halfs go togther in one four positions). The only other trick is to reset the brushes in the brush holder with a small pin or piece of wire. After re-assembling the two halfs, pull the pin.
TulsaFred
Looks like a job for original JB Weld
Fred
dklawson
I agree that it looks like a GM alternator. Is it really necessary to modify the mounting ear on the alternator case to get the pulleys to line up when used on an A-series?
Sarastro
There's plenty of information here on alternator conversions; start with the Wiki. I wouldn't recommend the Moss kit. Last I looked it was about $180 for a $60 alternator, a few parts you can make yourself, and instructions, which you can find here. I wouldn't use any alternator where you had to grind down the tab; it just weakens it, and there are others that fit without this modification.
RyanBez
All alternators do the same thing...it shouldn't matter what the replacement is as along as it fits in the car/bracket...
M
Mike
Thanks guys. Your responses have been very helpful. I will definately look for an alternator that does not require and grinding. The one I had was poorly mounted from the start. I'm surprised it took this long to break at the mounts. I also notice that it had only one mount point, the tab which had broken. Still learning about my Sprite!
Mike
Gerard
Mike
Mike, this fits using all standard hardware. I do a 1 wire conversion, which makes hookup even easier.
https://gerardsgarage.com/Garage/Tech/alternatorTfisher.htm
BillW103
I’m a fan of the GM alternator. I’ve used them on every thing from hot rods to tractors $50 anywhere. I think the 1275 was the toughest install. Milling the small ear was the easiest but as I was installing I wondered how long it would last.(3 months) I milled out the center of the big side but didn’t like the all the force on the water pump. I built a bracket that bolts to the motor mount plate and it seems to be working well. Now I can bolt a stock GM alternator in with no milling.
Gerard
I have a brand new GM one I want to sell if anyone is interested.
M
Mike
Guys:
Again thanks for the responses. What I gathered from all of the info is that there are a lot of alternators that can work. It's a matter of being fitted properly. I found an alternator and brackets on page 11 of the Victoria British catalog that looks like it will fit my 1275 (72-79) and they also have the proper brackets for which I'm in need of. Any other words of advice is much appreciated.
Thanks again.
https://www.victoriabritish.com/icatalog/sm/images/0127.jpg
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
E GT6 Help electrical guru needed Triumph 4
R Rust in Block? Help needed! Austin Healey 6
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
J BJ8 Turn signal help needed. Austin Healey 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
T TR2/3/3A help needed! fuel problem Triumph 25
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F General MG Help needed with su dual carburetor identification MG 4
S Wedge TR8 Starter wiring help needed Triumph 18
TomMull Air compressor help needed Restoration & Tools 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
Lukens TR2/3/3A help needed Triumph 6
A Fuel Gauge - Help Needed Austin Healey 18
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
E Singer wood frame help needed. Other British Cars 3
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
A BJ7 - Help Needed Austin Healey 3
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
B Help Needed with Upholstry Problem! Austin Healey 19
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
Tinkerman TR 3 Picture HELP Needed Triumph 5
S Help needed... Sunbeam (Rootes) 7
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
C Mallory dual point recurve help needed Austin Healey 6
Tinkerman Speciality Paint Help Needed Triumph 4
TR4A_IRS Help needed with high idle Triumph 13
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
Wirewheels Remote purchase help needed! Triumph 8
S Spitfire Spitfire front suspension help needed Triumph 9
R TR 3 Conv. top help needed Triumph 10
rcufley A little ignition help needed Triumph 123
6 Rear brake help needed Austin Healey 10
Brooklands MG Parts ID help needed MG 4
abarth69 quick help needed Spridgets 3
