Ok, lets try it this way. After you remove the top, but while the bows are still erect; hold the main bow in one hand while you smack the indicated point with the heel of the other hand. The joint may be stiff if the bows haven't been put down for a long time (or since being painted), but it should fold eventually. Be careful not to get your fingers pinched! After both sides have folded partway, you can usually press down on the main bow to get the dog leg to fold some more.
Once both joints are collapsed to about a 45 degree angle, then you can lay the bows down and hopefully wind up with the position that Russ showed above.
PS, It's hard to tell for sure, but your photo kind of looks like the screws through the bracket into the body have oval heads instead of flat. If so, you might want to change them, as the dog leg is probably going to drag on the screw heads and rub off the paint.
