MGA MGA Wire Wheels Conv
GB1
Is it possible to remove wire wheel hubs from half shafts and mount them on the studs to get wire wheels on a steel wheel vehicle. I know that the offset (how much) will be different and the lugs recess will be different, but has/can it be done???
Thanks Pat
Steve_S
I believe the splines under the hubs will be different. You may also run into problems with your tires rubbing on the fenders because the axle tube is 2" longer on a steel wheel car.
tony barnhill
Great Pumpkin - R.I.P
I would think you'd want to change the entire rear end like on an MGB.
GB1
GB1
Thank you gentlemen
I have seen bolt on conversion kits that I beleive use original ww and have some extra halfshaft, so I was wondering if it was possible. I was expecting 1/4 to 1/2 wider track (due to ww offset?) and was just testing the waters to see if anyone had done this and of course save a few bucks.
Thanks
Pat
tony barnhill
I always believe in doing the job properly & correctly the first time around....where I try to save a few bucks is using quality, OE used parts when possible...that's allowed me to extend the budgets on all my projects more than doing a job 'on the cheap' & then having to redo it! JMHO
GB1
GB1
I agree Tony, this is for my brother who likes chips.
billspohn
There is a very simple answer to this - no.
That's the bad news.
Want the good news?
You CAN convert to wire wheels with adaptors - from a Triumph. TR-3 through TR-6 used a bolt on adaptor, same bolt pattern. You need the special nuts as well (they fit 7/16" which is the same as the MGA but not MGB which are 1/2")
On TRs they cut all the studs down so that the wheel clears the studs. I have always considered this to be a silly way to do it as it means you have to install new longer studs if you ever want to reverse the conversion. What I always do it have a spacer plate machined up out of alloy that has the same effect.
Here is a pic of a set I did (the hubs are MGB so have had the studs replaced with MGA studs)
Steve_S
Do keep in mind that the adapters will widen your rear track a bit. IIRC, I believe it's around 3/8" per side, or 3/4" total.
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
Marvin Gruber MGA MGA wire wheel swap question. MG 3
ronzet MGA MGA wire harness routing and dressing MG 6
Editor_Reid General MG GT-49, national annual meeting of the North American MGA Register MG 0
C For Sale MGA MG Classifieds 0
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
TomMull MGA Rumble seat MGA MG 3
P For Sale MGA factory hardtop for sale. MG Classifieds 0
PAUL161 T-Series MGA pressure plate verses MGTF pressure plate? MG 6
T MGA MGA MG 6
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
M MGA MGA Engine Rattle MG 10
T Wanted Wanted : MGA rear deck cover MG Classifieds 0
M MGA RHD MGA dash finisher MG 0
BritFullHouse For Sale 56 MGA engine parts for free!! MG Classifieds 2
R MGA MGA Headrest fairing for R/H side MG 0
D MGA with T9 gearbox on a tow dolly MG 9
C MGA MGA Thoughts MG 20
C For Sale MGA wiring harness MG Classifieds 3
S For Sale MGA Factory Workshop Manuals on CD/ROM - All Models 1955 - 1962 MG Classifieds 0
Rut MGA MGA in Tuscaloosa, AL MG 3
P mga mint decklid 55to 63 MG Classifieds 1
K MGA 1960 MGA Vin MG 3
B MGA Mystery MGA chassis part MG 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
HealeyRick MGA Interesting MGA Fastback MG 9
H MGA MGA engine weight? MG 3
D MGA MGA turn signals MG 3
doc50 MGA Decipher MGA engine Code MG 4
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
Alfred E. Neuman Red MGA MkII Spotted 1
JPSmit MGA - on a journey Spotted 9
A MGA MGA valance fastener MG 2
3798j MGA Coupe Spotted 1
glemon MGA MGA extravaganza MG 4
AngliaGT MGA Coupe Spotted 1
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
oxford Healey vs MGA Austin Healey 31
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
NutmegCT MGA MGA front grilles MG 4
NutmegCT MGA MGA opinions? MG 23
AngliaGT MGA Anyone Looking for an MGA Project? MG 8
Alfred E. Neuman MGA Question for the MGA coupe owners - will I fit? MG 8
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
S MGA 56 - early mga 1500drum brake car MG 5
S MGA MGA Wiring diagram MG 1
R MGA Experience buying an MGA from a US Vendor - Vendor Review forum? MG 8
RickB MGA Looks like a nice MGA grille, $50 on Seattle Craigslist MG 1
S MGA mga top and side curtains MG 4
