Mallory dual point recurve help needed
Chris_Masucci
Hi folks,
I'm getting ready for starting her for the first time again, but would like to have a local distributor shop do the curve. This BJ8 engine has one of Elgin cams profiles that has 268 deg duration. Compression is roughly .5-.75 over stock of 9:1. Also has headers and is fully balanced and blueprinted.
Does anyone have a baseline curve for a fast road setup that we can start from?
Thanks!
johnea
Chris,
I have spent many hours recurving a Dual Point Mallory on my distributor machine to get the best out of my modified BN6. I ended up using home made two stage advance spring sets to stretch the curve to at least 3800-4000 RPM before max advance came in. For my setup the best curve was somewhat similar to the standard distributor: In the low revs a bit more advance than standard and higher up the rev range a bit less. This is what worked best for my engine. Your cam profile/CR. is not drammaticly different from stock so a curve close to the original dizzy might be a good starting point. Good luck!
C
Chris_Masucci
Hi John,
Thanks. Do you by any chance have a photo or plot of the stock curve? I can't bring my Lucas since it isn't original to a Healey, it came from a Jag...and it's old so any curve read from it would certainly be wrong.
Chris
johnea
Hi Chris,
I do not have a plot or a picture, but for an MKIII, you should be able to find all the distributor data in the GENERAL DATA section of your workshop manual . . . . . .
John
Patrick67BJ8
Hi John,
Chris
Have you tried Jeff at Advanced Distributor?
C
Chris_Masucci
Yep, I know about Jeff. I was trying to be lazy, since I figured there are several guys here in town that can work with Mallory distributors, and if I had a curve to give them they could certainly do it. Oh well, I'll get it sent to Jeff after I make sure she still runs.
M Mallory Dual point distributor Austin Healey 0
B Mallory Dual Point gap Austin Healey 4
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
D pertronix for mallory dual point Triumph 5
A Mallory Dual Point Dist MG 6
tontonene Mallory Dual Point Distributor Austin Healey 25
B TR2/3/3A TR3 Pertronix conversion for Mallory Dual Point Triumph 18
C Mallory dual point settings Triumph 1
W Mallory distributor on '60 BT-7 Austin Healey 4
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
D Experience with Mallory twin point distributor. Austin Healey 5
Jim_Stevens TR2/3/3A Distributor clamp with a Mallory? Triumph 5
aeronca65t A35 Race Mallory Park-UK-2015 Racing 7
memphis Mallory Distributor Austin Healey 0
6 Mallory Coil/Pertronix Q? Austin Healey 5
T Mallory ignition Triumph 14
DNK Mallory help Triumph 0
T Mallory optical distributor Triumph 32
specialsports Mallory Dizzy Other British Cars 10
A 123 Ignition vs. Mallory Austin Healey 28
M Mallory Distributor Austin Healey 26
SCguy Mallory Unlite Distributor wiring Triumph 12
PeterK What coil to use for Mallory 2332001 Triumph 11
RSMTR8 Wedge TR8 Mallory Distributor Triumph 6
G TR6 TR6 Mallory Dist Triumph 10
R Mallory Unilite Distributor MG 6
B Mallory Unilite Restoration & Tools 1
R Bugeye dual horns Spridgets 16
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
aero3113 100-4 dual gauge Austin Healey 16
B Dual Circuit Brakes Austin Healey 3
B MGB New Dual SU's and Run-On MG 3
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
apbos Interesting dual cylinder Bugeye setup Spridgets 6
F General MG Help needed with su dual carburetor identification MG 4
A TR4/4A TR4A dual exhaust specs Triumph 3
T TR2/3/3A Dual circuit brakes Triumph 2
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
andrea Dual Beam LED Head Light Cree Austin Healey 4
steveg Fiat Dual Master Cylinder Austin Healey 7
maxwedge5281 dual circuit braking system Austin Healey 29
B TR6 Anyone know where to get a decent Exhaust Manifold for 72 TR6 [dual] Triumph 2
HealeyRick Dual Control Healey Austin Healey 2
