I have a leaking rear wheel cylinder (61 Bugeye) and started working on replacing it today. The phillips head screw that holds the drum on would not unscrew completely, is extremely hard to turn (shoes set loose or tight). After working it in and out for over an hour I got it to move a fair amount but never all the way out and eventually the head stripped out.
Before I drill the screw out I thought I would ask a couple of questions: was there something I should have done differently? I am going to do the other side too and want to avoid the problem if possible. It is so hard to turn I don't think an easy-out will work, I think I am going to have to drill it out. Any thoughts would be appreciated.
