TR2/3/3A help needed
Geo Hahn
You might also mention which way you are heading in case there is no one in San Antonio to help.
You can, of course, start and drive w/o the benefit of a clutch. Not something I care to do in city traffic (though I have) but a practical alternative for interstate travel where you can drive hours w/o having to shift.
If a rebuild of your old M/C would work - then almost any Girling .75 seal will work (TR, Jaguar, others) - I mention that in case there is a BAP auto parts or something similar where you are now.
CJD
Hey Russ...tried your number but it won't go through. If you can milk it to ft worth you are welcome to the one off my car...
Geo Hahn
There appears to be 3 BAP/Geon parts stores in Houston in case that is useful (none shown for San Antonio):
Store 21 3403 Gulf Freeway Houston TX 77003 713-227-1544
Store 22 6423 Richmond Ave. Houston TX 77057 713-783-5122
Store 23 5900 North Freeway #106C Houston TX 77076 713-695-0315
TexasKnucklehead
Kerrville is only an hour north of San Antonio. VTR will be held there 4-22 thru 4-25. Maybe you'll be forced to wait and hope MOSS or TRF brings one along -or someone has a spare. If you do happen thru Houston, I'm only a few miles off I-10 near the middle beltway (8-Sam Houston), I'd be happy to help, but I don't have a spare MC.
I have a feeling you have a bigger story than 'desperately' fully describes.
I wish you better luck.
TR4nut
Russ if you are still in need, try the South Texas Triumph club in San Antonio - from their website, Kent Kinard is president and lists his number as 210 859 9272
Tried to text you myself but not sure it went through, I have a spare, but in Houston area like Jerry.
[h=2][/h]
Lukens
Lukens
Thanks for your advice and offers. I've had a good vacation inspite of my clutch problems. Back in Florida, nearly home. I've started a new thread addressing the clutch (hydraulic) problems.
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
E GT6 Help electrical guru needed Triumph 4
R Rust in Block? Help needed! Austin Healey 6
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
J BJ8 Turn signal help needed. Austin Healey 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
T TR2/3/3A help needed! fuel problem Triumph 25
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F General MG Help needed with su dual carburetor identification MG 4
S Wedge TR8 Starter wiring help needed Triumph 18
TomMull Air compressor help needed Restoration & Tools 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
A Fuel Gauge - Help Needed Austin Healey 18
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
E Singer wood frame help needed. Other British Cars 3
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
A BJ7 - Help Needed Austin Healey 3
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
B Help Needed with Upholstry Problem! Austin Healey 19
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
Tinkerman TR 3 Picture HELP Needed Triumph 5
S Help needed... Sunbeam (Rootes) 7
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
C Mallory dual point recurve help needed Austin Healey 6
Tinkerman Speciality Paint Help Needed Triumph 4
TR4A_IRS Help needed with high idle Triumph 13
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
Wirewheels Remote purchase help needed! Triumph 8
S Spitfire Spitfire front suspension help needed Triumph 9
R TR 3 Conv. top help needed Triumph 10
M Help Needed. Alternator Question Spridgets 14
rcufley A little ignition help needed Triumph 123
6 Rear brake help needed Austin Healey 10
Brooklands MG Parts ID help needed MG 4
abarth69 quick help needed Spridgets 3
