Speciality Paint Help Needed
Tinkerman
I have a brake line and a clutch line that are routed through the engine compartment. They are from a set that I bought that are a combination of copper and nickle. They are kind of a dull copper color. They need to be galvinized in color. I thought I had a spray can of galvinize color, but I must have dreamt about it. I have none, local auto parts don't have any either.
Does anyone offer that color? If not what could I use as a substitute? A search of Eastwood did not turn up that color either.
Your thoughts greatly appreciated.
Tinkerman
Tinkerman
Tinkerman
Thanks, Tim. I have some paint that I got from Eastwood that will probably do the job.
Appreciate the quick reply!
Tinkerman
Don Elliott
Dick - I made all my own brake and clutch tubes for under the "bonnet". I checked the diameter and lengths I needed. Then I went to several local auto parts stores and checked their stock - usually on display in vertical tube racks. I looked for steel tubes with the right plating colour as well as at least one end fitting that was correct for my applications.
I selected them myself and bought the right ones and once home, I cut them to the right length, comparing them to the ones I had removed. I removed the excess length at the other end which may have had a wrong end fitting and bent the tubes them as the original ones. Then with my flaring tool, I put the original connections back onto the cut end of the tubes. They have been there for 22 years and still look correct and like new.
This photo is dated 2011.
Tinkerman
Tinkerman
Thanks Don, when you bent the tubes did you start at the M/C end or the application end?
Dick
George Zeck Square Headed Speciality Bolt ???? Spridgets 1
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 10
P TR2/3/3A Chassis paint questions Triumph 8
B Carnauba wax Vs. new ceramic paint sealants Austin Healey 35
