3000 BT7 Steering Wheel Restoration help needed
srickss
I am looking to restore the steering wheel for my 60 BT7. It has some cracking and is overall in need of some tlc. I cant seem to find a definitive answer on what products to use for the project. I want it to look original. Any help would be appreciated.
bob hughes
HBJ8 Steering Wheel Repair Experiment - VERY GOOD.
also
Repair to bakelite steering wheel BJ8
Check out the above items elsewhere in the forum, just plug in steering Wheel in the search thread and sifted through the pages.
:cheers:
Bob
S
srickss
Thanks Bob, I did see those posts. I dont want to grind up old records though. I was wondering how the kits are from places like Eastwood?
oxford
About 25 years ago I restored a 1927 Morris Oxford. All the Bakelite on the wheel had disappeared. I recoated the wheel using fiberglass resin coloured with black oxide cement colouring. I know this sounds odd but it worked and is still perfect today. You have to build up the coats and rotate the wheel as it dries so it doesn't sag, then wet rub and buff afterwards. You shouldn't use too much colouring, but build it up with several coats. I have done this on two vintage cars with great success. I too have to repair my Healey BN4 steering wheel. I'll fill the cracks first with an epoxy, possibly coloured black, sand, then coat the wheel with a few layers of the resin mixture then wet rub and buff. Don't know if it will work, but as I said, I did it 25 years ago and my wheel is still excellent. Good luck.
Matthew
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
J 3000 [BT7] with 100-6 Grill Austin Healey 2
S Aluminum wing vents for BT7 3000 Austin Healey 1
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
F Carpeting Austin Healey 3000 1961 BT7 Austin Healey 10
B Oil Pressure Issue Solved 3000 BT7 Austin Healey 1
D BT7 62 3000 Trans leak Austin Healey 2
A Healey 3000 MKII BT7 restomod Build Thread Austin Healey 67
D Center Shift 3000, BT7, slipping Austin Healey 1
C Removing windshield from Austin Healey 3000 BT7 Austin Healey 2
tri_carb_healey drain plug bolt size 3000 bt7 Austin Healey 6
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
J 1962 3000 MKII BT7 Water pump replacement Austin Healey 3
mrdibbles Abarth Exhaust System for Austin Healey 3000 BT7 Austin Healey 11
pbraun I thought it was a 100-6, but it's a BT7 3000 Mk I Austin Healey 5
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R 3000 Heater Valve Austin Healey 4
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
M Engine Stand for 3000 Motor Austin Healey 7
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
