Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
About to replace the water pump. Is it possible that I have to remove the radiator? It doesn't look like there will be clearance to remove the pump. Any suggestions? Thanks J
I replaced my pump several years ago and do not remember removing the radiator. It probably would make it easier, and save some knuckle skin, but at worst you could try loosening the top bolts to get some more clearance.
I found the service manual, and it indeed says to remove the radiator and the dynamo. That did not make sense to me. Much as you suggested, I was able to remove the radiator bolts and tilt it forward, allowing plenty of access. James
Welcome James, to the forum. You'll find lots of help here. Some of us give and take, some only give, and others only take. We welcome all types. Thanks for the feedback on the help given and the results of your efforts.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
