Spitfire Spitfire front suspension help needed
ScottFromNH
Good Morning,
I have a 1973 spitfire 1500, I am replacing the front suspension bushing, struts, springs, steering rack.
I am working on the passenger side of the car and trying to remove the top A-arm, I have the bolt next to the firewall out and working on the one closes to the bumper.
I have the nut off however I can not get the bolt to come out. I can turn the bolt with a wrench and I notice the bushings inside are turning with the bolt. No matter how much pressure I put on that bolt I can not get it to move. I have used a hammer to try and tap it out, I have use a Big C clamp with a bigger socket on the end with the bolt head and the other part on the end of the bolt to try and force it to pop out with not luck.
Any idea's of how I can get this out?
sd80mac7204
Heat and a really good penetrating oil. Sounds like the metal sleeve has rusted to the bolt.
sd80mac7204
PB works great. Just let it soak in.
dklawson
Other penetrating oils that work well are Kroil, Liquid Wrench, and the ever popular DIY mix of 50% ATF and 50% Acetone.
My suggestion would be to undo the large bolt/studs attaching the lower suspension brackets to the frame. That will allow you to take the entire A-arm assembly to the workbench where you can manhandle the assembly to deal with the bushings.
S
ScottFromNH
Ok thanks everyone for the help. This is a stupid question but do you heat up the bolt itself with the torch or do you heat up the A Arm end where the bushing sits?
Never really don't it before.
JImEgan
Heat the bolt, let it cool, heat, cool Heating the a arm will only melt the rubber and produce copious black smoke.
Jim
S
ScottFromNH
Thanks everyone for all the advice. I ended up using my grinder with a cut off wheel after trying to heat the bolt for 25 minutes didn't do anything. I just purchased new bolts for the suspension replacement anyways..
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
philman Spitfire spitfire front suspension Triumph 2
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
CJD Spitfire Spitfire Front cap Triumph 0
S Spitfire Question on front calipers 1973 spitfire part Triumph 9
S Spitfire Question front shocks and springs for 73 spitfire Triumph 5
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
9 Spitfire Spitfire front clip on a TR4 Triumph 17
dklawson Spitfire Spitfire MkIV/1500 - Factory Front Spoiler? Triumph 3
Jerseygirl Spitfire A lesson in Spitfire front springs... Triumph 4
C Spitfire Front Lowering an 80 1500 Spitfire? Triumph 6
IanF Spitfire Spitfire front spring questions... Triumph 13
M Spitfire SPITFIRE FRONT HUB SEAL Triumph 2
drooartz Spitfire MK 3 Spitfire with MK 2 front? Triumph 9
drooartz Spitfire Possible to lower front bumper on Spitfire Mark 3? Triumph 2
andi_byz Spitfire SPITFIRE FRONT SUSPENION Triumph 2
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
