A slight hesitation stumble at speed
Martinld123
Bronze
My 1956 100 BN2 with M upgrades has a miss at speed the same feeling you get when running out of petrol but just for a second and then smooths out. This happens while cruising in or out of overdrive while at a steady speed. The engine has a smooth idle with no sign of problems but miss seems to happen at lower RPM while cruising. Number 3 plug has more carbon then the other three plugs. I wonder if a valve seal could be leaking. The other three plugs have a clean coffee color. Maybe that is my problem. Any ideas. Thanks Marty
Bustren
Hi Marty
Had similar problem with my BJ8 converted to 3 HD8 carburettors. I calibrated the mixture for maximum power at full acceleration, then cruising at 80 km/h I got similar symptom, simply too lean mixture. Suggest you try 1/4 turn richer mixture on the jet screw, quite easy and reversible test. Brg Lars
In my experience, intermittent missing is usually ignition caused. Do the 'dark test:' run the engine in a dark garage--well ventilated--and look for arcing around the distributor cap and secondary wiring.
Just read an article in 'Auto Restorer' about a guy with similar issues with a '55 Chevy. He did all the fuel system checks--including a new carb--only to find it was an ignition issue.
Martinld123
Martinld123
Bronze
Brg Lars thank you for responding. I richened both carbs (SU H6 for 100"M") two flats richer and it seemed to get worse. Long story short, when tuning carbs it calls for 12 flats out as starting point but mine would never run well at that starting point so I end up at about 16 flats out to get engine to run the way I believe it should. All has been well for sometime until just recently when this miss developed. Last year I sent carbs out to a shop to be rebuilt but later I found out knowledge of owner was not very good. I wonder it if could be too rich?? 60 year old distributor could be factor so I have cleaned and oiled it but electric problems could be cause. Will run car tonight in dark to look for any arcing. Thanks Marty
Martinld123
Martinld123
Bronze
Bob, I just finished your"Dark Test" with interesting results. I did all of this at idle. There was a ring of light around each plug (at point where porcelain meets metal base) as each plug fires and when I touch the plug wires they glow but only at the point where I touch them. I was unable to get any kind of shock when running my fingers along plugs or wires. They are period correct, "Bumble Bee, black and yellow" plug wires sold in bulk from Moss and are unshielded wires. Maybe I should go to shielded wires but if I am not getting shock it can't be leaking too much? No arcing at distributor cap. What do you think? Thanks Marty
I have no idea what the rings of light around the plugs are but, theoretically, the only things that could cause them is electrical arcing or flame escaping, neither of which is good.
IMO, stranded core copper wires work best with original caps (with the pierce style connectors). I tried shielded, carbon core wires and got symptoms similar to what you are experiencing. I hear there is a TR6 distributor that will work in a Healey with the plug-in style connectors, but can't vouch for it.
Patrick67BJ8
I have a "top loader" cap/wires from Advanced. They are working well in my Healey.
busybrit
If you think it's the ignition system, I would suggest testing the strength of each spark which helps identify a ignition weak spot. I have a spark tester bought off eBay, use it many times on customers cars.
I set it up to jump a small gap, then continue to increase the gap until the spark fails to make the jump. Generally a good spark will jump a gap of about 1/2" before if starts to stumble. Another tester I have, I set up in series with each plug and I run four testers at the same time. This lights up a glow type plug. If you have a week one it shows up dull and occasionally it miss fires under load.
Just for reference, my 100 will jump a gap and remain steady at 19 to 20mm with a Lucas sports coil.
dcarlg
Dcarlg, I bought a Sports Coil a few months ago from Moss with say 3000 miles on it now. I am using Pertronix electronic ignition. Thanks Marty
Marty,
It's really frustrating to deal with defective parts after you correctly diagnose the problem. Good luck.
Douglas
Woodie hs2's slight hesitation under load Spridgets 40
P Slight engine hesitation Spridgets 7
K TR2/3/3A Slight surging at Idle? Triumph 11
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
S TR2/3/3A Slight clunk in the rear assembly somewhere. Triumph 3
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
busybrit MGB Slight starter motor noise MG 5
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
JPSmit Slight rant Other British Cars 9
V 1275 slight miss, what's the cause??? Spridgets 20
Anthony_S TR2/3/3A TR3a slight shake at 60-65 mph Triumph 8
M Slight bind in front brakes Spridgets 7
bigjones Slight timing problem Spridgets 3
longbridgehealey very slight miss Austin Healey 3
T GT6 slight vibration in GT6, with power Triumph 4
bigjones HS4 - 1500 - slight problem Spridgets 24
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
bigjones Slight wheel alignment problem Triumph 9
JPSmit slight rant - solenoid Spridgets 3
J Spitfire Slight intermitant 78 Spitfire Triumph 14
kodanja Slight changes Triumph 16
P Slight loss of brake assist until pumped once Triumph 4
Sherlock Suggestion for "slight" name change Rover / Land Rover 1
S slight clicking/tapping noise after a head rebuild Spridgets 4
Basil Slight problem with rear hubs [EType] Jaguar 7
D TR6 Rust and hesitation 71 TR6 6 Triumph 9
P TR2/3/3A Hesitation on acceleration, wants to stall at corners Triumph 5
O Hesitation on pulling away from stop Jaguar 25
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
GTP1960 TR2/3/3A Hesitation during acceleration Triumph 13
K TR2/3/3A SU carb...after jet centered...jet lever hesitation. Triumph 3
A Hesitation with HIF6 carb on A+ engine Spridgets 11
W TR6 TR6 Hesitation Triumph 9
C Hesitation Spridgets 7
F Missing and hesitation, only after a hot start Austin Healey 6
TR4A_IRS Hesitation Triumph 25
K TR2/3/3A TR3A: Occasional sputtering and hesitation? Triumph 4
jhorton3 Hesitation Spridgets 13
J MGB MGB and HIF44 SU Hesitation MG 9
ecurie_ecosse Back firing,hesitation. Spridgets 4
Aldwyn Hesitation at Acceleration Triumph 21
prb51 TR2/3/3A TR3 hesitation under load Triumph 4
S TR6 TR6 Hesitation and power loss Triumph 1
wingsandwheels TR6 TR6 Hesitation Triumph 4
John Moore Hesitation and Timing MG 2
C Hesitation under acceleration and at 3k? Triumph 8
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
Geo Hahn TR4/4A Stumble Off Idle When Hot Triumph 4
