Geo Hahn
My TR4 (ZS carbs, stock everything) does fine on hot days except when I have to sit through a long stoplight. Then it wants to stumble a bit when first coming off idle.
This occurs in 100°+ heat and only after the car has been driven long enough that everything under the bonnet is thoroughly heat-soaked.
If I can anticipate the stoplight change and blip the throttle a bit it will not stumble but if I simply take off as usual it will sputter for a few seconds.
Am I correct in suspecting that a heat shield for the carbs may improve this?
Not driving in 100° weather would mean not driving at all, so that isn't really an option here.
